Replacing "rough In" Opening - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-19-2013, 03:07 PM   #1
replacing "rough in" opening
Totally new to concrete and probably should have though of this prior to creating this hole but here goes. Decided to put a bathroom in the basement and cut the floor to access exesting plumbing, replace where necessary and run new. The hole is approx 7-8 ft long and starts out about 2.5' wide and narrows to a little over a ft. Now my questions are:
1. Do I need a bonding agent on the existing after cleaning it thoroughly?
2. Is rebar going to be necessary?
3. Is covering with plastic and wetting a couple times a day for 2-3 days going to be enough for it to cure.
Side note I live in Iowa and tempatures arent going to be above 60 for a while according to forecasts and the ground is pretty wet as is.
lk00331 is offline   Reply With Quote
Old 04-19-2013, 03:54 PM   #2
Concrete & Masonry
Rewards Points: 636
No, just brush it off until it's clean.
No, unless the sides are smooth, and then I would use rebar/Tapcons/steel mails/anything drilled into the sides of the existing to keep the patch from settling.
You don't need to even do that, the strength of that concrete will far exceed what is really needed w/o any special curing, especially in a basement.
The outside temp and weather will have no effect on the concrete, just pour away........
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 04-19-2013, 03:59 PM   #3
Thanks a ton! makes the job a lot easier knowing this!
Old 04-20-2013, 05:42 AM   #4
Rewards Points: 4,790
jo, you are too cool
stadry is online now   Reply With Quote
exterior door rough opening jgcable Building & Construction 2 05-24-2011 07:08 AM
Getting a furnace through a narrow opening? Sowchoy HVAC 3 02-15-2010 07:55 PM
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Replacing a Window with a French Door gtruji Building & Construction 1 07-31-2006 05:27 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
