-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   replacing "rough in" opening (http://www.diychatroom.com/f105/replacing-rough-opening-177583/)
lk00331 04-19-2013 03:07 PM
1 Attachment(s)
Totally new to concrete and probably should have though of this prior to creating this hole but here goes. Decided to put a bathroom in the basement and cut the floor to access exesting plumbing, replace where necessary and run new. The hole is approx 7-8 ft long and starts out about 2.5' wide and narrows to a little over a ft. Now my questions are:
1. Do I need a bonding agent on the existing after cleaning it thoroughly?
2. Is rebar going to be necessary?
3. Is covering with plastic and wetting a couple times a day for 2-3 days going to be enough for it to cure.
Side note I live in Iowa and tempatures arent going to be above 60 for a while according to forecasts and the ground is pretty wet as is.
jomama45 04-19-2013 03:54 PM
No, just brush it off until it's clean.
No, unless the sides are smooth, and then I would use rebar/Tapcons/steel mails/anything drilled into the sides of the existing to keep the patch from settling.
You don't need to even do that, the strength of that concrete will far exceed what is really needed w/o any special curing, especially in a basement.
The outside temp and weather will have no effect on the concrete, just pour away........:thumbsup:
lk00331 04-19-2013 03:59 PM
Thanks a ton! makes the job a lot easier knowing this!
stadry 04-20-2013 05:42 AM
jo, you are too cool :eek:
