Replacing One Side Walk Block - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-20-2014, 10:14 AM   #16
hboogz's Avatar
Rewards Points: 97
You would use that in place of the 1/2" x 4" fibrous expansion material ? How would apply this?
hboogz is offline   Reply With Quote
Old 06-20-2014, 10:18 AM   #17
Concrete & Masonry
Rewards Points: 568
Yes, it's used in place of semi-rigid "felt".
It's alot harder to attach and keep straight, but you may need to either pre-bend the corners and hold it in place as you pour, or try drilling into the existing surrounding concrete and attaching it. It's a bigger PITA to deal with, no doubt, but it's far easier to seal......
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
hboogz (06-20-2014)
Replacing Glass block vent Mijotter Building & Construction 5 03-28-2013 10:16 AM
Replacing a garage door with Concrete block wall Domenick Building & Construction 5 06-12-2012 10:19 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
