Replacing One Side Walk Block - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-18-2014, 06:47 AM   #1
replacing one side walk block
Hi y'all. I need to replace one sidewalk block and am planning on pouring it myself. What I am wondering about is the forms. I have poured a sidewalk from scratch with forms. But this is just one block.
To the 'north' of the block I am replacing is asphalt, to the 'south' is concrete apron of the drive. To the 'east' and 'west' are solid concrete side walk blocks.
Do I use thin hardboard as a form between each different material?
Can I get by just by placing expansion material next to each material and using the existing borders as a form?
Do use the existing boarders to screed the pour? If not, how do I do it.
LCIndy is offline   Reply With Quote
Old 06-18-2014, 08:00 AM   #2
joed's Avatar
Rewards Points: 12,036
Expansion material only. You only need forms to hold the soft concrete in place. The existing structures will act as forms and hold the concrete in place as it cures.
The Following User Says Thank You to joed For This Useful Post:
LCIndy (06-18-2014)
Old 06-18-2014, 11:27 AM   #3
Rewards Points: 1,314
joed is correct, I have poured many with just expansion material as a divider between the existing and the new.
Screed with the existing as the edging and use an edger for the little edge decoration, and let it cure.
All done.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
LCIndy (06-18-2014)
Old 06-18-2014, 12:36 PM   #4
Makes sense. I was looking at it and realized there was no room for a form and was at a loss for a bit. Duh, the form is already there. Thanks!
Old 06-18-2014, 03:21 PM   #5
hboogz's Avatar
Rewards Points: 97
Looking to accomplish the same exact thing. Would I need to lay metal mesh reinforcement? Also, what exactly is expansion material? Would you place that north and south?
hboogz is offline   Reply With Quote
Old 06-18-2014, 05:18 PM   #6
You need reinforcement only if you are pouring a large sized piece, or are planning on a lot of weight on it, the usual sidewalk is usually poured in 4' x4' squares and around 4" thick.
The expansion material is the 1/2" x 4" fibrous material in between the actual slabs. It is sold in the concrete section of your home improvement stores in usually 5' lengths.
ED
Old 06-18-2014, 05:31 PM   #7
hboogz's Avatar
Rewards Points: 97
Perfect. Thanks ED.
Would I need to seal that expansion with a sonolastic type of elastometric self-leveling caulk ?
I've seen that product used on edges of concrete sidewalks as they hit the building or between joints of concrete squares?
ED
Old 06-18-2014, 05:34 PM   #8
Caulking is usually done to keep water from penetrating into a living space. So It is just an unnecessary expense in a sidewalk, unless it abuts a foundation.
ED
Old 06-18-2014, 05:38 PM   #9
hboogz's Avatar
Rewards Points: 97
Got it. Thanks for the tip. In the event I do want to caulk, would I need to secure that expansion material 1/2" down from the finished sidewalk? Do you secure the expansion material to the adjacent concrete using tapcons or will the weight of the new poured concrete keep it in place ?
Old 06-18-2014, 05:49 PM   #10
As long as the expansion joint material is kept down and just below flush with the old slab while pouring the new . it will be permanently stuck between the old and new after the curing is done.
Remember to use an edging tool for a professional look.
ED
Old 06-19-2014, 08:59 AM   #11
hboogz's Avatar
Rewards Points: 97
ED - Thanks for the info. Lastly, safe to assume that the fibrous material should not be visible? Here in Queens, NY I've seen that black fibrous material visible between squares on their edges on plenty of occasions. I've also seen folks leave 2x lumber around edges. Not why people do that because it looks terrible.
Old 06-19-2014, 09:46 AM   #12
Visible or not visible, that is up to the individual home owner.
And I agree leaving the 2x forms is tacky. (AKA REDNECK)
ED
Old 06-19-2014, 09:55 PM   #13
Rewards Points: 4,538
its called ' joint sealing ', NOT caulking as many misunderstand the term as they do ' masonry ' vs ' masonary ',,, yes, jnt sealing prevents wtr from leaking down under the slab & ' flushing ' the fines out of the sub-grade when a heavy load rolls across the jnt & the conc bends ( yes, conc does flex ),,, just as importantly, it keeps incompressibles OUT of the jnt so when the conc expands ( remember hy-skoul fizykx ? - solids expand under heat, liquids expand under cold ), the little junque doesn't ' spall ' the conc's edges,,, in a sidewalk, who cares,,, in a driveway, many are ignorant, on a runway, apron, or hgwy, its critical
on rte 9 in duchess cty, they used cedar strips for joint filler - same on 9w,,, exp jnt is usually left in place,,, evidently there are many ' rednecks ' in noo yawk still even tho they haven't had a mayor since ed koch & rudy
irc
The Following User Says Thank You to stadry For This Useful Post:
hboogz (06-19-2014)
Old 06-19-2014, 10:11 PM   #14
hboogz's Avatar
Rewards Points: 97
For good measure, while i have your ear. Which product would you recommend for the sidewalk square? Quikrete 5000? Perhaps with a dye that would match the existing? What about joint sealeant? sonolastic?
Old 06-20-2014, 11:09 AM   #15
Concrete & Masonry
Rewards Points: 542
If you're dead set on sealing the joints, I'd use something like this:
http://www.wrmeadows.com/deck-o-foam...-joint-filler/
The top 1/2" is perferated, and can be easily removed after the concrete cures, leaving a perfect profile for filling.
Also, Sonolastic works well. I've had good luck with Sikaflex self-leveling as well, and it's often available at HD......
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
hboogz (06-20-2014)
Replacing Glass block vent Mijotter Building & Construction 5 03-28-2013 11:16 AM
Replacing a garage door with Concrete block wall Domenick Building & Construction 5 06-12-2012 11:19 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 11:02 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
