Replacing Deco-drain - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-22-2012, 01:42 PM   #1
Replacing deco-drain
I have removed the deco-drain from my patio and I need to repair the 4x2 slot it created. The plastic bottom is still in and cannot be removed. What is the best material to use that will look like the rest of the concrete?
Jimdiane is offline   Reply With Quote
Old 03-22-2012, 07:38 PM   #2
Rewards Points: 14,010
Why was the drain removed? The reason I'm asking is if someone went to the trouble to install one there had to be a reason for it being there.
There will be no matching it exactly, I'd mist down the hole and fill it with premixed concrete. Make sure to keep going over it to forse the stones down into the mix.
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 07:23 AM
sewer gas odor after replacing tub drain botdob10 Plumbing 1 12-20-2010 12:08 PM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
