Replacing Damaged Lintel - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-30-2012, 08:13 AM   #1
replacing damaged lintel
hello all,
old french farmhouse with
1 meter thick rock/rubble walls, the mortar is limestone
wall height 7 meters
the old lintel's for a small window 1m x 1.4m are rotten and deteriorating
window is on bottom story
there are major cracks above the window, from existing lintel's to roof
job is to replace window with modern double panes
how does this sound??
1. retuck the existing wall
2. wait 2 days to dry
3. draw out window and lintel on wall
4. insert 4x4 above lintel
5. use jack to support wall
6. gently cut out existing wood
7. replace with new lintel wood or concrete
8. remove jacks, patch wall
9. remove rocks/rubble for window
10. install window
thanks
the_wanderer is offline   Reply With Quote
Old 12-30-2012, 09:21 AM   #2
Rewards Points: 13,960
Got a picture or two?
Replacing water line for refrigerator seannymurrs Plumbing 13 04-09-2011 06:30 AM
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 02:57 PM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 07:57 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 04:08 PM
