Replacing Basement Entry Stairs - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-16-2012, 09:01 AM   #1
My house was built in the 40's and the basement entry stairs are in need of replacement. On the left side of the stairs is a block wall that in leaning in toward the stairs. On the right side is the old well house that has a roof about 1ft above grade. The current water line from the existing well runs through this old well house, so access cannot be completely removed.
Questions: Can something be done other than completely excavating the old stairs and walls? Can the roof to the old well house be lowered below grade, or at least level with the other wall to enable Bilco doors to be installed over the entry?
Just trying to gather possible options before exploring this further. Thanks
psustang89 is offline   Reply With Quote
Old 03-16-2012, 10:19 AM   #2
Rewards Points: 2,238
It might be a good idea to post some pictures!!
rossfingal
rossfingal is online now   Reply With Quote
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Replacing old basement stairway and meeting codes lovebone Building & Construction 1 06-18-2011 05:40 PM
Basement Stairs (Canada, ON code?) SFX Group Building & Construction 12 10-29-2010 05:30 PM
Basement Stairs Question callmevo4short Building & Construction 3 01-19-2010 09:11 PM
