Repairing Chimney Crown - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-04-2012, 09:16 AM   #1
Repairing chimney crown
Hi. I just recently bought this house, and I knew it needed some work. I've just replaced the roof, but am still getting water in the basement at the chimney. The chimney cap is totally compromised. There were 3 layers of concrete/mortar, and at least the first two layers were completely compromised. I've got those first two layers peeled off, but the first layer that is anchored via the cement that went into the brink holes. So, that all said, I have a few questions. 1) Do I need to chip away at that first layer to ensure it's gone before pouring a new cap? 2) Should I take off the top couple of levels of brink shown in the picture? 3) If/when I pour the new crown, should the lip now hang a couple inches over those bricks that stick out just a little? What's my best route here? Here are a few pictures of the chimney. I hope these help you understand the issues I am facing. Thanks.
phrank is offline   Reply With Quote
Old 11-04-2012, 09:40 AM   #2
Rewards Points: 13,250
I'm sure one of the masons will be right along.
I'm more concered with what looks like some funky flashing that was done around where the chimmney goes through the roof.
I would have built a sloped cricket on the high side to devert the water away or at least added a kick out deverter just above it. (just a bent piece of coil stock in the shape of an L.)
Old 11-04-2012, 09:49 AM   #3
DIY staff
Rewards Points: 7,174
A mason will be along soon enough----
I've only done a couple of those----I like to have the cap project beyond the brick by an inch and a half or more-----
As to the bricks---When you break out the old cap----some bricks may come loose and need to be reset---
Remember===those chimney pots are easy to replace when the cap is off---so inspect for cracks and spalling----
Old 11-04-2012, 10:47 AM   #4
Concrete & Masonry
Rewards Points: 526
Ideally, yes. You may need to repair the top course or two of corbelled brick though.......
Only if they are loosened up by the cap removal, which is likely.......
Yes, 1.5" beyond the corbelled bick, more is fine too. Casting, or cutting after it's cured, a drip edge on the underside is ideal as well.
Be sure to be safe up there...........
jomama45 is offline   Reply With Quote
Old 11-04-2012, 10:50 AM   #5
I understand what you are saying, and I can see how a sloped cricket or a kickout diverter would have been helpful (I had to look up what those were). That said, we just finished putting a roof on the house, and it was a friend and his dad that do roofing all the time that led the job. Although they didn't do what you recommend, I watched how he did the flashing, and I'm 100% confident that there won't be a problem with that flashing.
Old 11-04-2012, 10:32 PM   #6
Thank you all for the advice. I've got an air chisel that I'll use to remove that top layer and along the sides the best I can. It will be interesting, to say the least. Thanks again.
Old 11-04-2012, 10:56 PM   #7
http://www.handymanclub.com/projects.../chimney-crown
Old 11-05-2012, 08:55 PM   #8
Excellent step by step instructions. Thank you!
Old 11-09-2012, 10:39 PM   #9
Replacing chimney crown
My dad is helping me with the project, and we've gotten all the concrete chiseled away. We also have a mold all set, and we are planning on mixing and pouring tomorrow. I just wanted to confirm that regular QuikCrete cement is ok to use. My dad was told that it would be best to use QuickSet because it dries faster and harder. What is best to use? Thanks!
Old 11-10-2012, 12:54 AM   #10
DIY staff
Speed is no advantage---regular set is easier------be sure to plunge a trowel around the edges to settle the concrete and prevent air pockets.
Do not make to sloppy a mix---must be stiff enough to hold its shape as you crown the top.
phrank (11-10-2012)
Old 11-12-2012, 08:06 PM   #11
Replacing chimney crown (success!)
Hi again. I just wanted to come back here and post a few pictures of the completed project. I think it came out rather nice. Thanks for all your advice!
The Following User Says Thank You to phrank For This Useful Post:
oh'mike (03-18-2013)
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 11:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Installing a new chimney crown ikessky Building & Construction 3 09-12-2010 10:54 PM
Is this a good method for repairing chimney crown/liner crack? meltdowndave Roofing/Siding 4 03-04-2010 08:56 AM
