Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-17-2013, 10:09 PM   #1
repair unlevel garage floor
Our garage floor appears to have a slight dip just inside of where the overhead door closes. In the winter, water pools in these dips which is quite dangerous and slippery. The constant water has also caused concrete damage. We patched some of the damage last summer but now have new areas that are crumbling. We want to repair the dip and then seal the floor. We are thinking about using a self leveling floor resurfacer and then seal it with epoxy. We are concerned that using this approach may not fix the problem as we would not have a proper slope to the whole garage floor. Some suggestions and guidance would be greatly appreciated.
mcleod73 is offline   Reply With Quote
Old 01-18-2013, 07:40 AM   #2
1st off, welcome to the forums but didn't anything ask for a location ? might not be an issue here but always helps us - pics do, too, but you're new so might not be poss.
pooling water should only be dangerous/slippery if it freezes OR pools in a hard-trowel'd floor,,, normal water doesn't cause conc damage while wtr dripping from my gutter will over time IF the drip hits the same spot during every rain [ reminder to self - FIX THAT &^$@$*((#^# LEAK ! ]
think you've got the method however may have bought wrong mtls ( apron / vest store ? ) - the dip/s call'd a ' birdbath ' - be particularly careful to grind the area to prep it & blow off all the dust,,, get a polymer-modified repair mortar that allows feather edging,,, self levelers aren't my choice as they never do unless you're a pro this is trowel & straight edge work,,, sealing's another thread & epoxies [ NEVER use wtr-bas'd epoxy ] aren't my choice but you might 1st repair it see then see what's next on the list,,, think about grinding ' slope ' from where the garage door sits on the threshold to where conc floor abuts the d/w,,, that helped us immensely,,, best thing to remember is wtr runs downhill
ope to the whole garage floor. Some suggestions and guidance would be greatly appreciated.[/QUOTE]
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 01-18-2013, 10:27 PM   #3
Sorry forgot to mention we are in Edmonton, Alberta, Canada
Old 01-19-2013, 07:13 AM   #4
knowing you're up ' there ' would have made a difference,,, pls re-read the post & mentally add-in a sprinkling of ' eh ? ',,, should be more relevant then
Rotten sill plate in garage - repair strategy? Simon96Taco Building & Construction 27 10-03-2012 06:23 PM
Shower floor repair pinkertonpv Kitchen & Bath Remodeling 18 08-23-2012 10:03 PM
New garage floor is chipping and dissolves easily. AAL Concrete, Stone & Masonry 1 06-04-2012 06:47 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
