Repair Stucco On Block Wall. Advice? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-03-2014, 12:18 AM   #1
Rewards Points: 24
Repair stucco on block wall. Advice?
Hi there,
I've got to repair some stucco on my exterior block wall. First, I need to determine what the finish is actually called. I believe it's called heavy lace or sometimes they call it arizona texture. Although some of the pictures of a heavier skip trowel also resemble it as well. I have a picture of the wall here with my car keys for perspective. Can someone tell me what it is, how it was done professionally and how I would recreate it? I have a bit of knowledge on stucco and have the tools. I can even rent if needed. Im curious what type of stucco I would need as well. I know there's different mixes of aggregate in them....
Thanks for any advice...Chris
stupid48 is offline   Reply With Quote
Old 02-03-2014, 12:45 AM   #2
Rewards Points: 14,306
OK so where's the picture?
Old 02-03-2014, 07:53 AM   #3
Concrete & Masonry
Rewards Points: 636
SLow down, and re-read the OP. Here's a hint: Click on the word "here" that is highlighted in blue................
jomama45 is offline   Reply With Quote
Old 02-03-2014, 08:06 AM   #4
Sorry I missed it.
The words are all the same color on my screen.
Old 02-03-2014, 08:11 AM   #5
Rewards Points: 582
You must have good eyesight jomama.
Hold the trowel at an angle of about 45 degrees and apply small amounts of stucco to the wall. Go over it all lightly with the trowel held flatter.
stuart45 is offline   Reply With Quote
Old 02-03-2014, 10:58 AM   #6
Rewards Points: 24
Thanks. I have to agree the hyperlink is hard to see....
So, in your opinion, what is the finish actually called. Is it a skip trowel? Also, is there a specific type of stucco to be used for the different coats? I know there's typically three coats but I wasn't sure if the finish/texture coat would have more aggregate maybe?
Old 02-03-2014, 01:35 PM   #7
Rewards Points: 462
The color of text that a link shows up in, is an option/preferences setting in the browser of the viewer. Dark blue against black can be hard to see. In Firefox it's under Content, ->Colors.
ChuckF. is offline   Reply With Quote
Rigid XPS to block wall bluefoxicy Insulation 11 12-19-2013 09:07 PM
Filling Concrete Block Cells to Repair Wall Wildbill9000 Concrete, Stone & Masonry 1 08-29-2012 06:39 PM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Garage CMU partial wall - shifted block ChrisJJ Building & Construction 9 04-01-2011 12:27 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-08-2009 11:49 PM
