Repair Exterior Stucco On House.... - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-17-2012, 01:06 AM   #1
Rewards Points: 24
Repair exterior stucco on house....
Hi there,
I had a freon leak on my central air and the technician had to cut out a 12"x"12 part of the stucco to repair the copper pipe (turns out the original a/c installer on our new house didn't use a tubing bender and instead just kinked the pipe instead (but that's another story)). So, I see that there is some stryofoam, wire mesh and some stucco with a texture finish. Does anyone have some advice on how to repair this? If you've ever seen a standard house in Nevada or Arizona, that is the type of rough texture that the wall has now.... Just looking for some tips on doing the stucco and creating the finish. I'm assuming it's a type of rough knockdown....
Thanks, Chris
stupid48 is offline   Reply With Quote
Old 07-17-2012, 03:30 AM   #2
Rewards Points: 582
Can you put a photo on please?
stuart45 is offline   Reply With Quote
Old 07-20-2012, 03:20 AM   #3
Rewards Points: 24
Pictures....
I have two pics... One is the hole and one is the stucco itself..
Old 07-20-2012, 03:46 PM   #4
Rewards Points: 582
Looks a bit like Tyrolean or pebble dash that's been painted.
http://www.wbs-ltd.co.uk/wetherby-sy...rolean-render/
Have a look at WBS dry dash(pebbledash) on the same site at the left.
Old 07-20-2012, 05:40 PM   #5
Rewards Points: 24
Hmm..
That dry dash looks more like something with aggregate in it. Looking at my stucco, I don't see evidence of that. I think the first picture might look like it has it but the second picture shows a bit more like pure stucco...
Old 07-21-2012, 04:44 AM   #6
Rewards Points: 582
Dry dash has the stones thrown on to the stucco, then pressed home with a wooden float. Wet dash has the stones in the mix before applying to the wall. Tyrolean needs a hand held machine to apply the stucco.
Old 07-21-2012, 09:39 AM   #7
Rewards Points: 582
Looking at the 2nd photo again you may be able to use a splatterdash coat. This is a wet slurry made using about 3/1/1 sand/cement/lime and flicked onto the wall using a hand brush dipped into the mix. This is also used for a key sometimes for the wall before it has stucco applied as it has a rough texture which provides a good grip.
Old 07-21-2012, 04:40 PM   #8
Rewards Points: 24
Thanks..
Thanks for helping me identify the finish...As a diy'er, it's always hard for me to find the right keywords to search for on the internet....
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 03:50 PM
Masonry Repair on Old House Chimney jmavro Building & Construction 9 04-16-2011 05:41 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 12:43 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
