Removing Tap-con - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-11-2013, 11:09 AM   #1
Rewards Points: 63
removing tap-con
Hi guys.
I started removing drywall from the previous owner in our basement.(did a poor job and most of it is unfinished).
He had tapconned the furring strips to the block foundation. with EPS under to insulate. I want to remove the furring strips and insulation however i cant get the tapcons out. I am using my 18v B&D drill and have had no luck. Any recommendations would be great....... would an air impact wrench do the trick, is it just cause i have a crappy drill?
Or should i just cut the heads off and patch the holes. and go from there....
chillz911 is offline   Reply With Quote
Old 02-11-2013, 11:14 AM   #2
Rewards Points: 13,266
#1 Why are you removing it?
If your going to go back and finish the area they can be left in place and just build a 2 X 4 wall.
Going to need an impact driver to get them out. Well worth buying one anyway. Very useful tool to have.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
drtbk4ever (02-12-2013), oh'mike (02-12-2013)
Old 02-12-2013, 01:21 AM   #3
cut them off with a multi-tool. HF has a cheap one and cheap bits. The metal is hard so go slow and let the bit cool often or you'll go through bits 2 per tapcon, I know from experience.
rebelranger is offline   Reply With Quote
Old 02-12-2013, 06:49 AM   #4
Rewards Points: 4,534
cold chisel & a 2# hammer works for us maybe not pretty but it'll be covered up, remember ?
Old 02-12-2013, 08:34 AM   #5
No way is a Muiti Tool going to be cutting off case hard screws. It would distroy the blade in seconds.
Old 02-12-2013, 11:26 AM   #6
@Joecaption - I can promise you that it works! I used 2 blades on my first tapcon because I went way to fast. Now I go slow, keep heat low, apply cutting oil and can get 2 or 3 per cheapo blade.
Old 02-12-2013, 12:28 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,... A 4" angle grinder would be a Much better choice, or better yet, the BFHammer mentioned by itsreallyconc....
Bondo is online now   Reply With Quote
Old 02-12-2013, 01:43 PM   #8
everyone loves a b-f hammer
Removing Old Stucco Without Damaging Paper greenfrog5 Drywall & Plaster 3 12-31-2012 10:33 AM
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 07:22 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
removing treated lumber edging pacifier1er Landscaping & Lawn Care 3 07-02-2008 01:08 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
