Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-15-2013, 09:34 PM   #1
removing stone tile from chimney for flashing installation
hi guys,
I have a cultured stone covered chimney and recently I found out that there is a leak through the flashing and I need to replace them.
However because it was fully covered with the stone i will have to remove the bottom part of the stone where it meets the roof to be able to install the new flashing.
My question is while the bottom stones are removed would it affect the ones up above causing it to collapse?
Here is a picture of what kind of stone it was on my chimney and the chimney is actually wooden chimney and not concrete.
Any info would be greatly appreciated.
re3456 is offline   Reply With Quote
Old 01-15-2013, 10:24 PM   #2
Concrete & Masonry
That''s considered an "adhered veneer", so technically, it should hang on it's own with no reliance on the stone below it. Quite often, we install thin stone from the to top down, to keep the stone cleaner. That being said, you may be challenged to remove only "some" of the stone at the bottom w/o creating collateral damage to more stone above.............
jomama45 is offline   Reply With Quote
Old 01-16-2013, 01:03 AM   #3
Thanks for the reply, actually the roofer will do the removal and flashing work, some of the bottom small pieces has already fall off so I was hoping they could start from those gaps and hopefully it's easy enough for them to remove the pieces.
One thing I was planning to do is to put the pieces back on myself. I was wondering if there is any adhesives out there that can be used for this application or I should call a mansor to do it proper way?
Again any info would be appreciated, thanks
Old 01-16-2013, 06:18 AM   #4
mason would probably use mortar,,, how comfortable do you feel matching the existing mortar's color OR can you live w/the new mortar being appreciably different in color ?
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 01-18-2013, 07:58 PM   #5
motar being different colour wouldn't be a big deal as it is at the bottom of the chiminey and you can hardly unless u climb up there.
However because it is not that big of an area that will be removed, I'm now thinking maybe I should just use something like PL Premium and glue them back myself, is it a good idea?
Ceramic plank tile installation question = More Difficult than standard tile? gtothek Tiling, ceramics, marble 9 10-05-2012 08:53 PM
Installing Stone Veneer Over Tile (see pic) bpdavis0 Tiling, ceramics, marble 10 05-29-2012 09:06 AM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Duraceramic verses stone tile Ldieker Tiling, ceramics, marble 2 11-23-2010 06:05 AM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
