Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-21-2012, 08:03 PM   #1
Removing old paint spots from Sandstone
I have old paint spots on the sandstone slabs that support my front verandah posts (see photos below)
I have tried to scrub. No success.
I have tried high pressure water blaster. Still no success.
I can't use acid so I'm at a loss as to what I can do to get rid of them.
Any suggestions? Please???
Removing old paint spots from Sandstone-dscf1056.jpg   Removing old paint spots from Sandstone-dscf1055.jpg
Wandererone is offline   Reply With Quote
Old 12-21-2012, 08:07 PM   #2
Another pic
Old 12-21-2012, 09:50 PM   #3
Unfortunately that sandstone is so soft that the stains go really deep,i doubt you'll find anything that will remove them,but you might try a course abrasive.
As an after thought have you tried bleach??
Canarywood1 is offline   Reply With Quote
Old 12-22-2012, 07:23 AM   #4
just had to remove paint from brick hearth due to sloppy repainting of the mantle & used a needle scaler,,, IF they're oil paint stains, try a poultice of fuller's earth ( diatomaceous earth ) & xylene/tolulene/naptha ( choice ),,, apply & let sit covered so the sun won't dry it prematurely,,, IF you scrub w/liquid, it'll just dilute stains and drive 'em into the stone deeper
of coarse your mileage may very compared to birdman's
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 12-23-2012, 05:16 AM   #5
I've actually just hit it twice more with the high prssure cleaner and it's pretty much gotten most of it off.
Well at least enough that it doesn't stand out so much anymore.
Old 12-23-2012, 05:50 AM   #6
glad we could be of help forgot to mention nothing is uv-resistant so, if you could live w/it, fade would happen naturally,,, another feature is that you don't see it anymore - only visitors do - go back to bed - ooops forgot you were in oz
Old 12-26-2012, 01:55 AM   #7
Best place to be at this time of year
Cheers
Old 12-26-2012, 04:11 AM   #8
I wouldn't be able to sleep until all traces of paint was gone so I'd get up in the middle of the night and try a light dusting feathered out with my sand blaster.
Fairview is offline   Reply With Quote
Old 12-28-2012, 04:22 PM   #9
Sleepless over a couple of paint spots Fairview???
I'd be a bit of a zombie then as they have been there for quite a while
Old 01-04-2013, 10:25 PM   #10
Guywithskills
I don't know what kind of paint it is, but I have used brake fluid. Apply with a brush to cover the paint, give 20 minutes and it will start to lift. We used to do this on old signs to strip them and repaint them. You are just applying a film over the paint. then come back with detergent joy to remove brake cleaner and power wash. You do have to be careful with stone, you dont want to scar it or removed the time developed "stone laquer" as i haveheard some call it.
Guywithskills is offline   Reply With Quote
removing oil paint from interior cement wall shrinkinfoot Painting 0 08-31-2011 07:10 PM
Damaged paint when removing tape somuchjackson Painting 11 08-10-2011 08:07 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
