Removing Mastic & Adhesive From Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-05-2013, 08:30 PM   #1
Rewards Points: 183
Removing Mastic & Adhesive from Slab
I'm looking for an experienced opinion on reconditioning my basement concrete slab. It has a layer of black mastic that originally held tiles and another layer of carpet adhesive. Can this be professionally ground down without contaminating the house? The companies that are interested in the job say "Yes", but I'm a little concerned about it. I'm looking at finishing the slab with an epoxy coating or elite-crete. Any opinions suggestions would be appreciated. Thank you in advance!
Jim Ignatowski is offline   Reply With Quote
Old 09-05-2013, 08:36 PM   #2
Rewards Points: 4,442
certainly,,, small cimex-type concrete grinder & 60grit segments,,, we'd grind wet & use a wet/dry vac as its very possible there's asbestos in the cutback adhesive
eliteCrete's imo
Old 09-05-2013, 09:08 PM   #3
Rewards Points: 183
Thanks for the reply. That's exactly my concern. So when evaluating a company to do this work, should I insist on them griding it wet? Does the type of concrete grinder they use matter?
I think they all use some kind of and some had actually mentioned having the vac stationed outside the house. Thanks again.
Old 09-06-2013, 04:28 AM   #4
grinding dry makes dust - its the nature of grinding dry,,, wet = no dust
Tags
adhesive , basement , epoxy , mastic , slab
Removing Carpet Adhesive glyndwr Flooring 0 10-20-2011 11:37 PM
Adhesive for large ceramic tile over concerete slab GeauxCajuns82 Tiling, ceramics, marble 2 11-18-2010 06:13 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
removing mastic from plywood mike6x7 Flooring 0 02-20-2010 03:03 PM
Ceramic tile on slab - install over adhesive left from vinyl tiles? softwareguy Flooring 1 08-23-2008 11:48 PM
