Removing Layer Of SLC - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-08-2012, 01:52 PM   #1
Rewards Points: 640
removing layer of SLC
I poured Self leveling underlayment, I believe it was Henry 555 dry mix that came in bags about a year ago now and used the Henry brand primer it recommended first.. well turned out I made a mistake and shouldn't of done it where I did. Is this stuff hard to remove? It is only 1/8" to 1/4" thick at most and one end I can completely get under since it stoped at a door jamb and have about a 1/16" lip above the rest of the concrete floor.
Is it possible to just slide an air chisel under that lip and take it up in sheets or chips without destroying the original concrete slab? some damage is fine, but I don't want huge holes in it... thanks
BlueBSH is offline   Reply With Quote
Old 03-09-2012, 06:25 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,.... Try it, 'n let Us know.....
Bondo is online now   Reply With Quote
Old 03-09-2012, 06:42 AM   #3
Rewards Points: 640
well was hoping for a little bit of guidance before renting the tools
to add to this, the layer was poured over perfectly smooth concrete, only problem was it was uneven... now with a change in the project it's now a problem.. it was going to have a different surface put over it, but thats now out...
just was hoping someone would of tried this before.. hoping it didn't bond with the smooth concrete under it so it would come up easily or something
Laying second layer of subfloor GeorgeV Flooring 6 09-15-2011 09:48 AM
Installing shower pan. How do I measure a mortar layer thickness? sukhenkoi Remodeling 1 04-13-2011 04:06 PM
Removing layer of concrete yako123 Building & Construction 12 08-24-2010 08:56 PM
Second layer of asphalt roofing eefromjersey Roofing/Siding 4 04-04-2009 02:26 AM
