Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-22-2013, 09:13 AM   #1
Removing Fireplace Hearth - Questions
Hi All
First post!!
My wife and I will be closing on a house we bought in the near future. It's not our ideal house (Needs TONS of updates) - but the location works and the price is right.
My first project is to get the family room set up. There is absolutely no place for a TV given the lay out of the room. So my only option is to put a wall unit entertainment center in front of the fireplace. I know...I know... but...We never used the fire place in our old house and have no use for the one that is in the house we are purchasing. And like I said, this is my only option.
The problem I have is that I need to remove the hearth in front of the fire place so the wall unit sits flush up against the wall. It's a brick and mortar hearth. I'm wondering if all of the bricks on this hearth will come off leaving me with a flush surface where the bricks meet the fireplace. In other words, is the face of the fireplace normally made first and then the hearth is put down. Or is it possible that some of the fireplace is actually built on top of the hearth. Ideally what I am trying to do is simply remove the bricks making up the hearth with a hammer and chisel without any cutting of any bricks.
This is what I'm dealing with (see pic). To me it looks like the bricks that are up against the fireplace almost go under the actual face of the fireplace. Is that not the way hearth's are built or is this actually a possibility?
dschribs is offline   Reply With Quote
Old 02-22-2013, 09:25 AM   #2
More likly there's a footing under that whole area under the house supporting it.
I feel you will be shooting yourself in the foot on this one.
That fireplace would be a big selling feature to most people.
If there's gas avalble I'd be installing a gas log insert for heat during a power outage and for a great look.
Old 02-22-2013, 09:49 AM   #3
I don't plan on damaging the fireplace if I can help it. I would put down some slate tile in place of the hearth. I'm just trying to find out if this is as simple as just removing the hearth brick by brick without any cutting.
Like I said, this is my only option.
As far as selling, that's 20 years down the road at least....
Old 02-22-2013, 12:57 PM   #4
Stuck in the 70's
Blondesense's Avatar
It would be cheaper and easier to modify the wall unit instead of the fireplace. Maybe you could just remove the top mantle so the unit could fit closer to the wall. Then either custom build or modify your unit to fit over the hearth.
Our situation was worst than yours, with the hearth and the corner.
This is what I came up with.
Old 02-22-2013, 02:28 PM   #5
joed's Avatar
Is it a full brick fireplace and chimney or is a zero clearance unit? Full brick fireplace will likely not come apart flush with the wall.
Have you considered just removing just the wooden mantle and building your entertainment center on top of the existing brick hearth. You could put a wide skirt board around the bottom to cover the brick.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
joecaption (02-22-2013)
Old 02-22-2013, 03:18 PM   #6
How do I know the difference?? Can you tell from the photo?? We have our inspection next Wed and I can take a closer look at the fireplace and maybe some pics if you tell me what to look for.
In terms of building a unit, although I wish I was that handy, I'm not. We will be buying a wall unit entertainment center to put up against that wall.
Something like this.
Old 02-22-2013, 09:17 PM   #7
joed's Avatar
Based on the smoke marks I see above the doors and what appears to brick interior, i think you have built in place fireplace not a zero clearance.
Old 02-22-2013, 11:03 PM   #8
So then that's "bad" for what I want to do correct???
Forgive my ignorance - I know NOTHING about how a fireplace is even constructed!! I googled it and apparently there are several types of construction methods. Didn't help much.
After thinking about it, I think I can leave one layer of brick on the hearth and the entertainment center may be able to slide over that one layer provided the hearth isn't too wide. I can save the brick I take out and put the hearth back together if I ever decide I do want the fireplace back.
Old 02-22-2013, 11:48 PM   #9
The bricks going to be distoryed when you remove it.
Trying to break it up with just a hammer and a chisle will be like bringing a stick to a gun fight.
It would be best to go rent a electric impact hammer.
Old 02-23-2013, 02:26 PM   #10
Nest Home Improvement
NestHI's Avatar
I would leave the fireplace alone and explore putting in an entertainment center to place your TV.
Home improvement simplified! Serving the Triangle (Raleigh, Durham, Chapel Hill). Please visit us at
NestHI is offline   Reply With Quote
Old 02-23-2013, 03:57 PM   #11
bbo
i dont know the dimensions/layot of your room, but what about plaving a corner unit in there somewhere? or just to the side of the FP with the tv at a bit of an angle?
bbo is offline   Reply With Quote
Old 02-23-2013, 07:47 PM   #12
The room is small, narrow and long. 15' x 11'. The ONLY option I have is where the fireplace is. The only other thing I could do is put the TV over the fireplace but because the room is so narrow it would be way too high.
Old 02-24-2013, 04:34 AM   #13
we all understand the romantic side of being a diy'er but, since you haven't figger'd out how f/p's are built or what is a chipping gun, howzabout starting your h/o resume by hangin' pictures & hire this work out ? know you wanna do it & you'd like to do it but fearful you'll spend LOTS more by actually doing it + run the risk of causing more expensive-to-repair damage
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 02-25-2013, 04:09 PM   #14
Concrete & Masonry
My experiences would tell me that the band of brick wrapping the fireplace is sitting directly on the hearth, so you may need to take them down as well. Most likely, the hearth was built first, and you're going to have to take it all the way back to the concrete block. Not a huge issue, and you can likely do it with a hammer and mason chisel. You will be extremely lucky not to damage at least a few of the bricks though.
As for what's below, there should be a concrete "sub-hearth" holding the rick up. This is typically a part of the fireplace foundation that's poured concrete, and cantilevered beyond the fireplace to the floor joists. It's usually sloped on the underside to reduce it's thickness as it meets the floor joists. It should be visable from the basement............
jomama45 is offline   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
drtbk4ever (02-25-2013), dschribs (02-25-2013)
Old 02-25-2013, 07:24 PM   #15
Thanks!! Inspection is Wednesday so I am going to take a closer look.
My Hearth and Home direct vent gas fireplace is not working. ron500 HVAC 14 01-16-2013 09:36 AM
Re-facing fireplace, several questions! 6fthook Remodeling 27 10-20-2011 10:12 AM
Fireplace facelife - needing hearth advice louiejr Building & Construction 4 11-25-2009 06:57 AM
Please Help with Fireplace Hearth Planning BobnSofi Building & Construction 1 02-18-2008 07:26 PM
Removing a Fireplace - suggestions? BigFloyd Building & Construction 1 08-03-2006 06:01 PM
