Removing Concrete Shelf (fireplace) - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-09-2015, 11:17 AM   #1
Rewards Points: 14
Removing concrete shelf (fireplace)
Hello all I am a new subscriber to this wonderful forum . I am looking for a little direction on how to remove concrete shelf on my fireplace. Should I be using a sheldge hammer and chizel or circular saw? Not sure if the is rebar or what not inside. The concrete shelf is about 1' off the ground (floating) the fireplace is brick. I have purchased tile 3x2' to install over the brick for a modern look. Any advice would be appreciated.
Leigh82 is offline   Reply With Quote
Old 06-09-2015, 11:32 AM   #2
Rewards Points: 14,026
Without at least picture it's anyone's guess how to get rid of it.
Old 06-09-2015, 11:49 AM   #3
Rewards Points: 14
Sorry not sure how to add image I did try
Old 06-09-2015, 12:26 PM   #4
Rewards Points: 14
here are some pictures , hopefully they worked
Removing concrete shelf (fireplace)-20150609_094430.jpg   Removing concrete shelf (fireplace)-20150609_101636.jpg   Removing concrete shelf (fireplace)-20150609_095824.jpg
Old 06-09-2015, 04:58 PM   #5
Rewards Points: 1,232
You realize that you are going to have some type of inflammable hearth in that area, right?
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 06-09-2015, 06:04 PM   #6
That's a hearth not a ledge.
Why not just tile over it?
Old 06-09-2015, 06:06 PM   #7
Keep it. You need the hearth if you are going to use the fireplace . iMHO The floating hearth looks better than some massive structure up from the floor . If you tiling over the brick I would might do something similar on the hearth . I would be interested how one might tile over that rough brick .
jimn01 is offline   Reply With Quote
Old 06-09-2015, 06:08 PM   #8
Rewards Points: 14
I have removed the tile that was on the hearth. The fireplace does not host live fires anymore it now has a electric fireplace insert we are thinking of converting to gas in the future. Just want to remove the "hearth" and have extra room in our living space. We have 2x3 tile that we are installing directly on top of the brick I will post pics as the project takes place.
Old 06-09-2015, 07:22 PM   #9
Rewards Points: 4,750
we'd use elec chipping guns
Old 06-10-2015, 08:59 AM   #10
Unless you block the flue, you have to have a non-flammable hearth. It doesn't matter if you are ever going to use it or not, it is code and unsaleable without it.
The Following User Says Thank You to Tscarborough For This Useful Post:
stadry (06-10-2015)
Old 06-11-2015, 10:30 AM   #11
Rewards Points: 402
You have to use some non-combustible material put on the floor level hearth and under the firebox. It would be better to get the local building codes for installing hearth.
fortunerestore is offline   Reply With Quote
Old 06-12-2015, 01:41 PM   #12
Rewards Points: 14
so to update you on my project, i have removed the hearth, and 1 1/4 inch of brick from both sides of the fire place so i can fit my tiles perfectly. the job took some time but went smoothly. i have attached photos below if you are interested in viewing, today i purchased some thin set. i am able to apply this thin set directly to the brick , Ardex x77 (premium microfiber reinforced polymer modified thin set mortar) a 40lbs bag cost me $50. this stuff is amazing i watched a video on it, the guy applied a 24x24" file on the wall he then buttered another 5 12x12" tiles stacked onto the 24x24" tile and it held with no sag, i was sold. i am hanging 24x32" tiles so this product will be perfect. i will post pics of the finished product when project is complete.
Old 06-12-2015, 01:44 PM   #13
Rewards Points: 14
Here are some photos of my progress
Removing concrete shelf (fireplace)-20150610_164835.jpg   Removing concrete shelf (fireplace)-20150610_164913.jpg   Removing concrete shelf (fireplace)-20150610_181120.jpg   Removing concrete shelf (fireplace)-20150610_184938.jpg   Removing concrete shelf (fireplace)-20150611_095610.jpg
Old 06-12-2015, 01:46 PM   #14
Rewards Points: 14
And it continues.........
Removing concrete shelf (fireplace)-20150611_115458.jpg   Removing concrete shelf (fireplace)-20150611_142421.jpg   Removing concrete shelf (fireplace)-20150611_152804.jpg   Removing concrete shelf (fireplace)-20150611_152820.jpg
Old 06-12-2015, 01:47 PM   #15
Rewards Points: 14
sorry for the upside down and sideway pics
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Removing a Fireplace wilvelas Building & Construction 1 05-03-2011 04:17 PM
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 11:28 AM
Concrete over brick??? (updating a fireplace) cwelte Remodeling 11 03-28-2010 12:34 AM
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 03:28 PM
