Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-20-2012, 01:09 PM   #1
Removing ceramic tile
On floor and walls in bathroom. The mud bed is about 50 years old. And about 2 inches thick on floor.
What suggestion to remove from walls with mesh and mortar and Sheetrock.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 09-20-2012, 07:33 PM   #2
http://www.amazon.com/Bosch-11255VSR.../dp/B000BB79Q6
I use one of these with 2" wide bit.
I also use a 4-1/2 right angle grinder with a diamond wheel to cut into the corners and through the wire mesh.
Old 09-20-2012, 07:37 PM   #3
Super Moderator
More info----What are you doing with the floors? can you just tile over the old floor?
As to the walls----fans--tarps---dust masks and a big hammer---tin snips and other primitive tools of destruction are required.
more
oh'mike is online now   Reply With Quote
Old 09-20-2012, 10:35 PM   #4
more
No to tile over.
ThANKS
Old 09-20-2012, 10:36 PM   #5
ooooh ANOTHER TOY, very tempting!
Old 09-21-2012, 05:01 AM   #6
Super Moderator
Big hammer----electric chipping hammer ---more masks.
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Removing Ceramic Tile Blaze25 Flooring 2 11-16-2006 09:52 PM
