Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-20-2012, 10:50 PM   #1
fcooke's Avatar
Removing a/c unit from brick wall
I am removing an old a/c wall unit and need to fill the space with replacement brick. I can figure out how to repair the inside wall but first, I need to find a brick that matches and secondly need to learn how to do the brick work. What mortar do I use? What prep needs to be done? Do I work from the outside in? Is a vapor barrier needed? Any advice would be great.
fcooke is offline   Reply With Quote
Old 02-20-2012, 10:56 PM   #2
Far better on this one to hire a mason to do the brick work. There going to be able to a far better looking job. There going to have to cut out every other brick so it can be woven in so the repair will not show as bad.
Yes there's a vaper barrier needed, most often it's tar paper.
Old 02-21-2012, 07:18 AM   #3
The first thing I would do is find matching brick somewhere inconspicuous on your house, IE; around the side or back. Then remove the brick and use it to fill in the hole and fill in the hole where you took the brick from with close to matching.
COLDIRON is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
how to tell if a brick wall is load bearing eskowitz Building & Construction 10 08-01-2010 11:00 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
