Removing 2 Foundation Concrete Blocks - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-01-2012, 09:16 PM   #1
fastback4's Avatar
Rewards Points: 51
removing 2 foundation concrete blocks
I need to remove 2 concrete blocks so i can add 2 crawl space vents 14 feet apart. Not knowing much about concrete blocks i can only tell you there are 8 blocks laying in the crawl space that must have been extras and they each have 2 hollow spaces in them so i'll assume that is where you would put concrete . These blocks are maybe 16󭅌.
Question is how do i remove these blocks. I'll assume chisel around the mortar and tap with a hand sledgehammer.
fastback4 is offline   Reply With Quote
Old 03-01-2012, 09:29 PM   #2
Dynamite works great! Just use a little bit. No. You are correct. You can break them out with a hammer and cold chisel. Or if you have access to an AR15 rifle or larger 2 bullets will do the trick
Go with the hammer. If you need it you can rent a rotary hammer and you can drill out the block and then breaking it will be cake
robs660 is offline   Reply With Quote
The Following User Says Thank You to robs660 For This Useful Post:
fastback4 (03-01-2012)
Old 03-01-2012, 10:37 PM   #3
fastback4's Avatar
Rewards Points: 51
Thanks for the confirmation as i'm all out of 454 Casell rounds
Insulating Old Concrete Foundation bjr149 Insulation 7 06-04-2011 09:42 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 09:43 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 09:27 PM
