Removing 10" Concrete Pool Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-29-2013, 12:49 PM   #1
Removing 10" concrete pool wall
I am in the process of removing an in-ground pool. The vertical walls are 10" concrete and I can only get to one side. Any suggestions on how to remove?
lconner is offline   Reply With Quote
Old 12-29-2013, 06:05 PM   #2
Rewards Points: 14,312
Got a picture?
Hard to suggest how to do something without seeing it.
Why do the walls need to come out?
Why not just backfill it?
Old 12-29-2013, 06:34 PM   #3
joed's Avatar
Rewards Points: 13,752
Jackhammer work down from the top.
Breaker on the end of a back hoe.
Leave it and fill the hole.
Old 12-29-2013, 06:39 PM   #4
I can't figure out how to attach the photo but it is your basic in-ground pool. 3-8 feet deep. I plan to have a garden in that area so the upper few feet of the pool wall need to be removed. I have punched holes in the bottom surface for drainage already.
Old 12-29-2013, 07:04 PM   #5
Rewards Points: 3,834
Those walls are probably shotcrete,and full of wire reinforcing and maybe rebar, you'll need a big air hammer and a big compressor,and some wire cutters.
Canarywood1 is offline   Reply With Quote
Old 12-29-2013, 08:31 PM   #6
joed's Avatar
Gas powered concrete saw?
Old 12-29-2013, 09:02 PM   #7
Good luck with that.
Old 12-29-2013, 09:37 PM   #8
Msradell's Avatar
Rewards Points: 348
A Hoe Ram mounted on a backhoe or a track hoe is certainly going to be the only reasonable way to do that. You also probably need a good cutting torch to burn out the rebar! Another possible option would be if these have a good concrete cutting company in your area. They should be able to cut the top 3 feet of the wall off for you so you could put you into the pool area.
Unfortunately, because of how these are built there is not going to be any easy or cheap way to do it.
Msradell is offline   Reply With Quote
Old 01-01-2014, 05:50 AM   #9
Rewards Points: 4,806
i'd leave it & use the top of the walls for walkways
short of the track hoe & breaker, the only other reasonable choice would be wall-sawing,,, most conc cutting co's have the equip,,, is the cost worth the goal ? expect every lineal foot cut will cost $ 10 & that's probably the low base price
sure you still want to do this ? expect track hoe to be north of $ 2,500,,, isn't that walkway sounding better ?
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 08:39 PM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Plumbing line in exterior concrete for pool Hawk334 Plumbing 4 07-04-2009 10:13 PM
