Remove Silicone Based Sealant From Brick - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-17-2013, 12:27 PM   #1
Remove Silicone Based Sealant from Brick
Hi,
I layed old St. Louis solid Brick on the exterior porch and patio floors and interior kitchen floors of my house 6 months ago. The bricks are laid on a concrete slab.
After laying and mortaring, I acid washed with Muratic Acid, Let dry for 24 hrs, then applied Prosoco Limestone and Marble Protector (StandOff a Silicone based sealer). Within 6 weeks, the bricks have turned from a deep red to a light red/grey. It appears the bricks have effloresced under the sealer, and I have not been able to remove it using Prosoco's Safety Clean or Muraitic Acid.
It seems the only way to get to the efflorescence for removal is to remove the StandOff sealer with Prosoco's Dicone NC9. This will be a messy process, especially inside.
Any ideas would be welcome.
markstg is offline   Reply With Quote
Old 06-18-2013, 10:55 AM   #2
Rewards Points: 4,538
too bad you didn't 1st apply a vapor barrier to the slab,,, guess you're left w/plan b now what did prosoco's rep tell you ?
Old 06-18-2013, 01:08 PM   #3
Never thought to need a vapor barrier over the slab before laying the bricks. Neither did my bricklayer. Sure wish I had known better.
Basically Prosoco rep gave me a few bottles of their various cleaners and the Dicone and said to try small sections and see what works best.
Tried the Dicone and brick is coming out splotchy.
Old 06-25-2013, 06:12 PM   #4
http://www.concreteconstruction.net/concrete-surfaces/sealer-remover.aspx?utm_source=newsletter&utm_content=jum p&utm_medium=email&utm_campaign=CCIU_062513&day=20 13-06-25 ,,, what's the worst that could happen ?
Remove sealant from ceramic tile Ann Hebert Tiling, ceramics, marble 4 09-30-2011 10:35 PM
How to remove silicone? Philj Kitchen & Bath Remodeling 1 05-07-2011 02:11 PM
removing oil based paint off of brick handycanuck Painting 1 06-18-2010 01:14 PM
Remove silicone from painted walls ? skyblues Painting 4 03-23-2010 06:32 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
