Remove Poured Concrete Block - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-04-2013, 12:05 AM   #1
Hi!
I'm hoping to find some answers here regarding a poured concrete block in my basement.
I'm starting to look into remodeling my basement, but currently something is literally BLOCKing me from doing it. The previous owners poured concrete on the basement floor to put a wood stove. The stove was removed because it was against code, and now I'm left with a useless block in the middle of my basement space.
I've attached pictures, and if anyone could give me pointers on the best way to remove it, I would greatly appreciate it.
Don't mind the dog kennel and mess currently on top of it- new puppy
doingitgirl is offline   Reply With Quote
Old 08-04-2013, 05:20 AM   #2
Rewards Points: 13,712
I'd be using my Bosch Bull Dog Hammer drill.
A brick chisel and a pair of goggles would also work.
http://www.bing.com/images/search?q=...electedIndex=1
Old 08-04-2013, 06:06 AM   #3
Rewards Points: 4,648
bulldog's a great tool but this is too much for it unless you have lots of time,,, get a heavier ( 30# ) breaking gun,,, probably the pad will come up in chunks IF you begin at the sides w/1 1/2" or 2" chisel,,, breaking from the top would also work but would probably be more difficult.
we have bulldogs but this calls for heavier guns impo
Old 08-04-2013, 07:10 AM   #4
Home Depot rents some bigger ones then the Bull Dog.
Only reason I suggested the Bull Dog is I already own one.
Old 08-04-2013, 07:34 AM   #5
suggests a tengental point, joe,,, just thinking of buying few more bosch guns,,, wow, the prices are astounding,,, granted i haven't had to buy small tools for a few years,,, even on craig's list, used bulldog's are $ 150,,, YIKES ! thank you, pres obama-yo-mama & chairman n-f-c bernanke
Tags
basement , block , cement , concrete
Grinding concrete to remove carpet glue, and matching height of existing laminate... dmh0284 Flooring 12 04-22-2015 04:51 PM
best way to remove nails in concrete block BlueBSH Building & Construction 29 09-19-2014 06:23 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
To Remove Concrete Slab in Bathrooms? fletch7 Remodeling 7 08-05-2011 08:58 AM
