Remove Leaded Solid Rod Irons From Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-09-2012, 03:43 PM   #1
Rewards Points: 190
Remove Leaded Solid Rod Irons from Concrete
I will be covering my old 11x30 concrete patio this week with small gravel possible roofing paper and sand to put pavers over it. The concrete is in terrible condition and water collects on it. I am trying to remove the rod iron railings that go around it but I cannot get them out. After chiseling for the last hour it look like they were set in the concrete with lead... I cut on of the rods off with a metal saw but there is about 4 inches still sticking out of the concrete I need it leveled with the concrete. The post or solid not hollow which I was surprise to find. Any ideas to remove it? I tried using my propane torch but its to low and it keeps going out. Never saw anything like this
ryanb4614 is offline   Reply With Quote
Old 08-09-2012, 03:53 PM   #2
Rewards Points: 502
Have they got to come out completely, or can you cut them flush with the surface with an angle grinder (disc cutter)?
tony.g is offline   Reply With Quote
Old 08-09-2012, 03:54 PM   #3
Rewards Points: 190
I would just cut them flush but I cant get close enough
Old 08-09-2012, 04:50 PM   #4
Rewards Points: 502
How come? Pic(s) would help.
(trying to cut them with a hack saw would be a pain!).
Old 08-09-2012, 05:34 PM   #5
Rewards Points: 3,628
Ever heard of a sawzall,it's what the're for.
Canarywood1 is offline   Reply With Quote
Old 08-09-2012, 07:02 PM   #6
bbo
I'm with tony. Id rather use an angle grinder than a sawzall for this application.
bbo is offline   Reply With Quote
Old 08-09-2012, 08:08 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... Ditto that,....
Bondo is online now   Reply With Quote
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 09:03 AM
How to remove old glue from concrete slab? bulldogrsp61 Flooring 10 01-01-2012 10:32 PM
Remove floor tile set in 3/4" concrete Dmeyr Flooring 31 12-14-2011 11:07 AM
Remove mastic from concrete slab CountDowne Flooring 2 11-14-2011 03:52 PM
can i install solid bamboo over sheet vinyl on concrete? KrispyDIY Flooring 16 03-23-2011 05:08 PM
