Remove Grout From Concrete Slab? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-09-2013, 08:40 PM   #1
Rewards Points: 22
Remove grout from concrete slab?
I have an outdoor patio that I removed tile from and I need to remove the grout that was under the tile.
What's the best way to do this without damaging the concrete? I plan to polish and seal the concrete and use it as the patio floor.
Any advice is appreciated.
gekkie96 is offline   Reply With Quote
Old 03-09-2013, 08:50 PM   #2
Rewards Points: 83
Rent a concrete surface grinder from a local rental company.
Or
Hire a mason to skim coat it with some fancy mortar.
mech_gui is offline   Reply With Quote
Old 03-09-2013, 09:29 PM   #3
DIY staff
Rewards Points: 7,174
Yep---rent a concrete grinder----a floor buffer with carborundum stones will remove the bulk of the thinset---but might not get it clean enough for staining-----
Old 03-09-2013, 09:33 PM   #4
Rewards Points: 22
Homedepot rents concrete floor grinders with diamond blades. What grade or grit should I use for initial removal and then for polishing?
Old 03-09-2013, 09:39 PM   #5
DIY staff
I'm going to move this to concrete and masonry for you---those guys are the ones that have grinding/staining experience---Mike----
Old 03-09-2013, 09:41 PM   #6
Rewards Points: 22
Thanks oh'mike
Old 03-09-2013, 10:11 PM   #7
Rewards Points: 960
Remove the concrete and start over with a new slab.
cleveman is offline   Reply With Quote
Old 03-10-2013, 07:43 AM   #8
Rewards Points: 4,752
polishing an exterior slab tell us you're already in over your head so stop watching those tv shows,,, estimating decent polisher rental $ X # days rqd X your experience = many $$$ + poor final finish,,, the absolute best way to do this is hire someone who's got skill & experience,,, 2nd best is renting a DOUBLE disk edco diamond grinder,,, 110v & easier to ' work ' than 1disk which is an inappropriate tool for this,,, yes, their diamond inserts are a pita as they're secured by oak wedges but you should quickly learn how to properly attach them after 2 or 3 dislodge while grinding
for some odd reason, grout lines often ' telegraph ' up thru coatings,,, even a n-hood kroger super-mkt shows 'em on polished/stained conc after vinyl tile removal.
if this IS an exterior slab, forget polishing,,, apply 2 ( or even 3 ) coats of a good polymer-modified cementitious overlay material & continue from there,,, this was & is often discussed on ' concretelocator.com ',,, pay close attn to the ' tag line ' - there's NOTHING for this job at any apron/vest store,,, trust me, you need specialty mtls & equip,,, don't recall anyone else posting on these threads who does this work but moi altho jomama may poss have done some conc sealing.
our local apron store ( & many others ) rents a ' diamabrush ' which fits their lo-speed buffers & does a great job w/diamond-impregnated ' fingers ' rather'n stones.
anyone posting encouraging responses tells more about themselves than the task at hand,,, polishing's extremely specialized work - takes very special equipment, 7 ( at least ) sets of diamond grit tooling, & experience only gain'd by time on the job,,, ' replace the slab ' is another possibility but i wouldn't unless its in horrible condition,,, then again, have only done this work for 15yrs so he may have more experience to share
Remove all old grout before regrout? charliebarkin Tiling, ceramics, marble 0 04-28-2012 01:42 PM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
How to remove old glue from concrete slab? bulldogrsp61 Flooring 10 01-01-2012 10:32 PM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
