Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-28-2012, 12:19 PM   #1
Removal of concrete pillar caps
Does anyone have experience in removing the standard 28 inch by 28 inch concrete cap from brick driveway pillars?
bjbooth
bjbooth is offline   Reply With Quote
Old 09-28-2012, 07:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Front-end loader/ backhoe comes to mind,...
Why ya takin' it down,..??
Old 09-29-2012, 05:17 AM   #3
An old Tradesmen
Moved to Concrete forum.
Old 09-29-2012, 09:19 AM   #4
A picture of the area would be helpful. I guess my question would be what happened to the pillar? I'm assuming the structure or whatever was being supported is no longer there. How deep is the foundation and is it solid?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 09-29-2012, 09:20 AM   #5
Not my idea...but a stubborn friend has two pillars to which he previously applied some sort of epoxy coating to the concrete caps. The caps are now decomposing from the edges and, of course, the epoxy is peeling, etc. I wanted to strip epoxy and repair concrete in place with a good product such as Cement All, but he purchased two new caps. Now we are faced with the task of removing the old caps without damaging the decorative brick pillars.
He was hoping to remove old caps in one piece by undermining the mortar between the top course of brick and the cap, as opposed to sledging them out from the top. I'm not sure this is possible and hoped others may have had experience and, of course, some tips and techniques.
bjbooth
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
Interior concrete paint removal help needef julieingranbury Flooring 0 10-24-2011 12:34 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
