Refinishing Concrete Step - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-07-2012, 09:19 PM   #1
Hi,
I have an older concrete step that has spalled a little. I want to refinish it.
I would like to use something that is waterproof because there is cold storage underneath.
Would someone care to recommend a product that would create a nice finish and be waterproof ? What is the process ?
I've heard of silicates or something ...
Mike Mike is offline   Reply With Quote
Old 05-08-2012, 09:16 AM   #2
Rewards Points: 152
There is a product callled "rockite" used for cement repair,refinish. Iv havnt actually used it yet but i have heard good things from other pros in the concrete industry.
The process would be to grind out the cracks so you can have a sufficient amount of space to use the repair materiel.
good luck
TRUEPRO is offline   Reply With Quote
Old 05-08-2012, 08:16 PM   #3
Rewards Points: 3,410
Originally Posted by Mike Mike View Post
Hi,
And if you can't find what truepro reccomended,you might give this a try.
http://www.quikrete.com/pdfs/project...ngconcrete.pdf
Canarywood1 is offline   Reply With Quote
Old 05-09-2012, 02:19 PM   #4
Too Short? Cut it Again!
Whatever you use you have to get all the marginal existing concrete out of your way. Sort of like preparing a tooth for a crown or filling. Then I use this from Abatron. It is an epoxy, easy to work and shape and will be very strong and waterproof.
Old 05-12-2012, 06:15 PM   #5
As far as cleaning the existing concrete before resurfacing, is just washing OK?, or should it be etched ?
Old 05-12-2012, 06:42 PM   #6
Just as long as you get all the loose stuff off,it's okay to flush the surface to do this.
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Please help with concrete front porch and step mdambrosio Building & Construction 6 05-26-2011 08:48 AM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-23-2008 12:22 AM
concrete step repair & slate gemelli2 Building & Construction 5 10-03-2007 07:38 PM
