-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Refinishing Concrete Step (http://www.diychatroom.com/f105/refinishing-concrete-step-143058/)
Mike Mike 05-07-2012 08:19 PM
Hi,
I have an older concrete step that has spalled a little. I want to refinish it.
I would like to use something that is waterproof because there is cold storage underneath.
Would someone care to recommend a product that would create a nice finish and be waterproof ? What is the process ?
I've heard of silicates or something ...
TRUEPRO 05-08-2012 08:16 AM
There is a product callled "rockite" used for cement repair,refinish. Iv havnt actually used it yet but i have heard good things from other pros in the concrete industry.
The process would be to grind out the cracks so you can have a sufficient amount of space to use the repair materiel.
good luck
Canarywood1 05-08-2012 07:16 PM
Originally Posted by Mike Mike (Post 916798)
Hi,
And if you can't find what truepro reccomended,you might give this a try.
http://www.quikrete.com/pdfs/project...ngconcrete.pdf
user1007 05-09-2012 01:19 PM
Whatever you use you have to get all the marginal existing concrete out of your way. Sort of like preparing a tooth for a crown or filling. Then I use this from Abatron. It is an epoxy, easy to work and shape and will be very strong and waterproof.
http://www.abatron.com/components/co...23f6364581.jpg
Mike Mike 05-12-2012 05:15 PM
As far as cleaning the existing concrete before resurfacing, is just washing OK?, or should it be etched ?
Canarywood1 05-12-2012 05:42 PM
Just as long as you get all the loose stuff off,it's okay to flush the surface to do this.
