Refacing Fireplace W/ Coronado Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-27-2012, 05:42 PM   #1
Refacing fireplace w/ Coronado Stone
Greetings
We have a roughly WxH 6x12 fireplace I want to reface with coronado stone. Can anyone brake down what I need to do to the existing fireplace before I start applying the stone to the bricks?
chrysagon200 is offline   Reply With Quote
Old 05-27-2012, 05:45 PM   #2
pic of my fireplace
pic of current fireplace
Refacing fireplace w/ Coronado Stone-p1010042.jpg
Old 05-28-2012, 07:05 PM   #3
Concrete & Masonry
Rewards Points: 470
Really not much to do if the brick is clean. The stone can be adhered directly to the brick in this case. You will want to plan out what you're going to do with the hearth overhang though. And plan an approach that will allow you to change out the FP doors if necessary in the future.
jomama45 is online now   Reply With Quote
Old 05-28-2012, 07:13 PM   #4
thanks
Thanks for the reply and information. I plan on just bricking up to the sides of the FP grill cause we are gonna replace that as well.. yes the bricks are clean, but do I have to put a scratch coat of mortar or something on the surface of the brick fireplace? before I start mortaring the stones and placing them on the on the fireplace?
Old 05-28-2012, 07:25 PM   #5
Rewards Points: 3,342
No scratch coat is required.
Canarywood1 is offline   Reply With Quote
Old 05-28-2012, 07:30 PM   #6
Concrete & Masonry
Rewards Points: 470
Ditto.......
Old 05-29-2012, 12:53 AM   #7
thanks
any advice on mortar, or tips on starting the stone work? little things like " that would of been a good trick to know before I finished it " ... new to masonry..
Terry
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 05:57 PM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 07:39 PM
Fireplace w/ TV focus point. Stone to ceiling or not? POLL 6fthook Interior Decorating 2 05-25-2011 10:02 PM
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 05:58 PM
