Reface Brick Fireplace With Faux Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-15-2012, 03:11 PM   #1
Reface brick fireplace with faux stone
Has anyone refaced a brick fireplace with faux (or even real) stone? I'm thinking of doing this and wondering if with just enough mortar and the cut stone pieces, if I can apply it straight to the cleaned brick. Or if some kind of backer board would have to be affixed to the brick first, then the stone face on top of that.
cypherx is offline   Reply With Quote
Old 06-15-2012, 06:04 PM   #2
Rewards Points: 3,512
I've done faux stone on an outdoor wall,and put it directly on the brick,but did have to add about a 2 lb. coffee can full of portland cement to the bag of mortar mix i used,so the mortar would hold the stone up,other wise it just wanted to slide off,and it's still there 30 years later.
Canarywood1 is offline   Reply With Quote
Old 06-17-2012, 10:43 AM   #3
Rewards Points: 152
You can stick Real or PREcast stone to brick allllll day long as long as the brick isnt painted. GL
TRUEPRO is offline   Reply With Quote
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 04:57 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 04:03 PM
Are cornerstones needed for faux dry stack stone fireplace? Lisa Highfield Building & Construction 0 06-09-2010 06:36 PM
Arguement over faux stone on a fireplace viper1 Building & Construction 13 01-07-2010 03:52 PM
