Recoloring Stamped Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-30-2012, 06:37 PM   #1
recoloring stamped concrete
My stamped patio was completed about 5 years ago. I'm trying to get it to look like it did when it was first finished. Any ideas how to achieve this? The concrete itself is in great condition just needs recoloring.
The first pic below is what it look liked when it was first finished, color only. The second pic is what it looks like now.
Last edited by cyras21; 05-01-2012 at 07:20 AM. Reason: to emphasize reason for first pic
cyras21 is offline   Reply With Quote
Old 04-30-2012, 07:04 PM   #2
Too Short? Cut it Again!
Really, really Nice stamped and stained concrete work.
But I only see one photo and not what it looks like now.
Some reason you cannot call the concrete artisan that did this for you originally?
Old 04-30-2012, 07:10 PM   #3
that looks really good and i also only see 1 photo
mcfarton is offline   Reply With Quote
Old 04-30-2012, 07:49 PM   #4
this is my patio now
Old 04-30-2012, 08:23 PM   #5
Concrete & Masonry
Rewards Points: 470
It looks like it needed to be sealed, like 2 or 3 years ago already. If you like the way it looks wet, then a new coat of sealer should help immensly.
I would highly recommend attempting to have a site visit with the original contractor who put in in first though. Let them see it first-hand to ensure it doesn't need any additional prep BEFORE you have it sealed.
Although a DIY re-sealing is possible, it can also turn into an extreme disaster that will cost alot more to fix. I had a similar situation this year when a past customer thought they could just buy a "high quality water-based sealer" at HD and do it themselves. What a mess........
jomama45 is offline   Reply With Quote
Old 04-30-2012, 08:32 PM   #6
Yeah, I am NOT wanting to do this myself. The contractor that put it in, is coming to inspect. I just like to have an idea of what to expect before hand.
When it's wet it does look nice, but there are a few spots where the color has worn off.
Old 04-30-2012, 08:44 PM   #7
Concrete & Masonry
Rewards Points: 470
Generally speaking, if it looks good wet, it will look even a bit better when re-sealed with a solvent-based acrylic sealer. As for color loss, it looks like there may just be some effloresence, or other contaminents on the surface that are camoflauging the color below. If some color has left, tinted sealers are always an option. Good luck.
Old 04-30-2012, 10:44 PM   #8
Maybe I need new lenses but I see photo one and photo two with totally different concrete stainig and patterns.
You would not be trying to play us would you?
I worked with high end concrete artisans for ages. Strange people
Not one I know could turn photo one into photo two.
The Following User Says Thank You to user1007 For This Useful Post:
concretemasonry (04-30-2012)
Old 04-30-2012, 11:00 PM   #9
concretemasonry's Avatar
Rewards Points: 2,572
Definitely 2 different jobs. - Color range and pattern.
The first was a rectangular pattern and the second was a supposedly random irregular pattern. the first was a tan collor made with more permanent tan colors and the second was made with grays that probably contain carbon black and not black iron oxide because of the obvious pigment/colored dust costs.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
user1007 (05-01-2012)
Old 05-01-2012, 07:18 AM   #10
Yes, as I stated the first pic was for color comparison only. That's what the color looked like when it was first stamped, and the second (actual patio) is what it looks like now. I'm trying to get it back the the color in the first pic.
Old 05-01-2012, 08:23 AM   #11
Hmm, it seems that the shiny and lustrous appearance of your patio has been gone, but with proper product like for example, a gloss concrete sealer can bring back its previous state. not really sure of what brand is good, but you can conduct some research online.
TileLindsey is offline   Reply With Quote
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
laying stamped concrete over old tile Kimmarie Flooring 24 03-20-2012 01:20 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
prices for stamped and stained concrete scorpione General DIY Discussions 1 08-04-2009 08:02 AM
Stamped Concrete Sealer cgoll Building & Construction 1 06-24-2008 07:15 PM
