Rebuild Chimney Cheaply - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-22-2013, 08:18 AM   #16
Rewards Points: 236
your lucky. i have to take down my brick chimney, it goes through the middle of the house. i have to break the bricks loose and 'throw' them. you can just drop them. i am then going to replace it with a metal chimney. all diy.
Fix'n it is offline   Reply With Quote
Old 06-22-2013, 08:45 AM   #17
An old Tradesmen
Rewards Points: 7,816
Make it a B vent chimney if you only have a gas furnace and water heater.
Old 06-22-2013, 12:28 PM   #18
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
If you have a GAS furnace what do you need a brick chimney for now anyway? Most if not all newer gas furnaces seem to have forced exhaust and intake and sealed combustion chambers, you should be able to just run a round flu pipe out. At work when they replaced the furnaces 7-8 years ago with 92% efficiency ones, the installers used 3 or 4" PVC pipe for the flu on them, out the wall and with a cap.
$2000 to replace a brick chimney doesn't sound expensive to me, it's a lot of work, don't make the mistake of going with CHEAP materials anyway! you WILL regret it when you have to redo it in a few years when it fails!
RWolff is offline   Reply With Quote
Old 06-22-2013, 12:56 PM   #19
concretemasonry's Avatar
Rewards Points: 2,626
Eliminating the chimney also eliminates flashing, leaks, etc. around a chimney penetrating the roofing. Patching the old holes may even cheaper than fitting the new flash around a reolacement.ing and sealing. A new furnace will probably save on heating costs, with amount depending on the efficiency of the existing furnace.
Dick
concretemasonry is online now   Reply With Quote
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
chimney: repoint or rebuild? wombosi Building & Construction 11 10-10-2011 02:44 AM
fireplace and chimney top rebuild??? syborg Building & Construction 18 01-16-2010 02:58 PM
