Rebuild Chimney Cheaply - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-21-2013, 12:41 PM   #1
Rewards Points: 664
Rebuild chimney cheaply
I want the cheapest way possible to fix this chimney. This chimney vents the furnace and hot water heater. Currently the house is vacant and the gas is off. I have estimates of over $2000 to demolish and rebuild this.
I would like to save money by doing the demolition myself and have someone who knows what they are doing rebuild the chimney with inexpensive materials. This is the rear of the house and I do not care about appearance. Does demolition simply involve me going up there with a hammer and chiseling out every brick? When I have it rebuilt it does not have to be brick? What is the least expensive way to do this and still have a working chimney? Thank you all in advance.
crescere is offline   Reply With Quote
Old 06-21-2013, 12:42 PM   #2
Rewards Points: 664
Closeup of problem
Old 06-21-2013, 12:44 PM   #3
Rewards Points: 664
pieces are falling off
Old 06-21-2013, 12:57 PM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 740
Oil furnace?
I had the same problem. I had a "friend" do the labor for 1700 bucks. I bought the bricks. The cheap job ended up crooked at the top.
I then had to change the liner as that is what caused the problem in the first place. Then I had to change the oil tank. Three years goes by and the insurance company asks for pics of the tank and cancels any insurance to do with an oil leak. This was a ULC listed tank, but the company that made it had leaks in some of their tanks.
My point is this. If it's oil, toss it all and change to natural gas. I ended up changing after all the grief. You can then knock down the chimney as you won't need it any more.
I wasted about 4 grand with that oil set up.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 06-21-2013, 01:29 PM   #5
Rewards Points: 664
No, this is gas. I just want to know what is involved in demo of the brick chimney and rebuilding it with something cheaper than brick. What about just having a metal chimney straight up?
Old 06-21-2013, 03:22 PM   #6
Rewards Points: 664
I just noticed that this has been moved to the concrete forum by a moderator. No offense to masons, but most of them tell me I need new brick. I am hoping to use cheaper material that will still work like maybe a metal pipe with aluminum around it etc. I have seen this while driving around on other houses.
Old 06-21-2013, 04:09 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,132
How about tearing it all down..build a box to keep the flue in...and then cover that with brick vernier panels?
Old 06-21-2013, 04:37 PM   #8
Oso954's Avatar
Rewards Points: 766
A good HVAC company should be able to provide an exterior furnace flue or tell you who can. Depending on your furnace, hot water heater, and local codes, you might not be able to share the flue. You might need separate ones.
Oso954 is online now   Reply With Quote
Old 06-21-2013, 05:12 PM   #9
Rewards Points: 3,418
Or you may be able to use metal pipe in a wood chase,check with your local building department,you'll get it right from the horses mouth there.
Canarywood1 is offline   Reply With Quote
Old 06-21-2013, 06:17 PM   #10
123pugsy's Avatar
Rewards Points: 740
Gas is good.
Can you not just run the exhaust/intakes right thru the wall w/o using a chimney?
My new furnace doesn't need a chimney.
The Following User Says Thank You to 123pugsy For This Useful Post:
oh'mike (06-21-2013)
Old 06-21-2013, 06:27 PM   #11
Concrete & Masonry
Rewards Points: 530
16" chimney block and 8x8 flues would likely be an easy and cheap way to meld that inti the existing below grade portion. If the correct cement is used between the flues, it should last a lifetime. Still going to be some expense to it though as it looks relatively tall.......
jomama45 is offline   Reply With Quote
Old 06-21-2013, 07:34 PM   #12
Rewards Points: 664
I have never taken a chimney down so my stupid question is if I demo the bricks that are already crumbling will the liner remain standing or will it fall? Is the chimney flue the same as a liner? I just want to be sure I do not make a mistake in overdoing the demo. I am certainly capable of breaking things so I can handle the take down. I just want it put back up inexpensively.
Old 06-21-2013, 07:37 PM   #13
Rewards Points: 664
I have had estiamtes of $2K to over $3K. Those numbers just do not work for me.
Old 06-21-2013, 07:41 PM   #14
Rewards Points: 664
Originally Posted by 123pugsy View Post
Gas is good.
No, it has to be 90% efficient appliance to do that I have been told.
Old 06-22-2013, 03:39 AM   #15
123pugsy's Avatar
Rewards Points: 740
I had thought about that after posting. Might be a good time to upgrade and lose the chimney. If you rebuild the chimney, eventually you'll need to change your furnace anyways so the chimney repair money seems like a waste.
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
concretemasonry (06-22-2013), oh'mike (06-22-2013)
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 11:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
chimney: repoint or rebuild? wombosi Building & Construction 11 10-10-2011 03:44 AM
fireplace and chimney top rebuild??? syborg Building & Construction 18 01-16-2010 03:58 PM
