Rebar Exposed On Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-04-2012, 12:24 PM   #1
Rewards Points: 1,062
rebar exposed on foundation
people,
wanting to buy this house, but the garage foundation has exposed pcs of rebar showing about every 2-3'. About 12-20" of bar showing/poking through, and repeats every 2-3', where the neaxt rebar was placed. This has probably scared many porospective buyers in the past (its a foreclosure), and I dont want to buy this house and have big problems selling it in the future.
Would you stay away from this? And is this a serious problem with foundations? (its a 1948 house, and heck- it hasnt collapsed...LOL)
Thanks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 03-04-2012, 12:30 PM   #2
Oh, the garage is built into the side of a hill-the back part of thegarage is quite high- say, 7-8' of concrete foundation UNDER GROUND while the front is of course, down to ground level.
Old 03-04-2012, 12:32 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Depends on how much more rebar is in there that you can't see.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
noquacks (03-04-2012)
Old 03-04-2012, 12:59 PM   #4
DIY staff
Rewards Points: 7,174
No picture?
Often long lengths sticking up indicate plans for a masonry wall on top of the foundation--
Could be the budget changed and they went for a framed structure instead of the planned brick or block --picture could help explain it--Rebar could be cut back so it doesn't allarm future buyers.
woodworkbykirk (03-04-2012)
Old 03-04-2012, 02:00 PM   #5
Originally Posted by oh'mike View Post
No picture?
Thanks, Mike, but I think you have the wrong idea- the bars are not sticking up/out/through, they are exposed- like after pouring, they cut the tops off, built the house, done. But after , I guess, they removed the plywood forms, rebar was showing on the SIDES of the wall.
I kniow a picture is a good idea- hmmm, maybe I can get it.....lets see......
Old 03-04-2012, 02:10 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
without seeing whats physically there its hard to say.. as mike mentioned it could be do to a change over in materials to reduce costs.. it could have also been because the rebar was just dropped into the forms without cutting it to length so now its sticking out of the concrete. it can easily be cut off with a mini grinder and a cutting wheel
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 03-04-2012, 03:56 PM   #7
joed's Avatar
Rewards Points: 12,904
I think what he is describing is rebar that was too close to the side of the pour and is exposed on the walls.
Probably something similar to this.
The Following User Says Thank You to joed For This Useful Post:
Old 03-04-2012, 04:05 PM   #8
Right!! thats it! except repeated many times- say, a few feet apart. On a wall thats a full 7-8' high. (still waiting to recv that pic so I can post it, if it still helps). Also, difference being the rebar is inside the garage, not outside like here.
Thanks, joed.!
Old 03-04-2012, 05:13 PM   #9
DIY staff
Unsightly but not a big deal--that wouldn't be a deal breaker for me---
If you can't stand looking at it--Parge the walls and bury it---
Old 03-04-2012, 05:25 PM   #10
Is the rebar rusting?
Hardway is offline   Reply With Quote
Old 03-04-2012, 05:46 PM   #11
couldnt tell by the pictures, but I would say no way steel can not rust after 60+ yrs, eh? Anyway, good to know its maybe not a deal breaker from Mike. Mightbe able to treat it/patch/paint/cover up somehow for future, if I wanted to. Hate to cut it with a disc, and then patch as I willbe weakening the whole wall, right?
Old 03-04-2012, 05:57 PM   #12
https://mail-attachment.googleuserco...e00b34789b174&
Old 03-04-2012, 05:58 PM   #13
Darn- server error ......
Old 03-04-2012, 06:26 PM   #14
DIY staff
I put that as 'funky by functional' and would not cut out the exposed rod---
Like you said--it's been there since it was made and hasn't fallen down---
Still doesn't sound like a deal breaker.
Do you have a skilled contractor that you could call in to assess the house for you?
Not an inspector--that is needed perhaps --but a person knowledgeable in older homes that could quickly go through the place and give you a thumbs up or thumbs down on the structure--and mechanical of the house?
Old 03-04-2012, 06:30 PM   #15
Is this normal??? Exposed wood near foundation of house? simiesue Building & Construction 19 01-04-2012 10:01 PM
Formula for concrete foundation, rebar? Daulton Building & Construction 3 03-20-2011 10:56 PM
rebar in foundation bluebird5 Building & Construction 13 02-02-2011 09:33 AM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 10:48 AM
Rebar Placement in a 3x3 concrete pad. Top, bottom or middle? Deck Building & Construction 32 05-11-2008 08:44 AM
