Ready Mix Mortar Consistency / Performance Issues - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-21-2012, 09:58 PM   #1
Unhappy
I'm at my wits' end regarding mortar Quikrete Type N mortar; no matter what I do, including letting it 'slack', adding more water, talking to it, gently rocking it in the wheel barrow, etc. it seems to amount to nothing more than very granular, grey, wet sand.
It starts out looking like a cement / sand mix, but on adding water the cement seems to almost disappear. In the end, its workability is non-existent. And forget about the creamy texture that I keep reading about - nothing creamy about it.
Over the last 5 years building small garden retaining walls I must have purchased several thousand pounds worth of 66 lb bags from different locations. It doesn't seem to be a bad batch issue, unless bad batches are typically shipped to Ontario ... lol!
What I hope members of this forum can contribute is
a) similar experiences with this brand of Type N mortar, so I don't start wondering about my water quality or sanity and
b) ideas about supplements for this mortar mix so that it actually becomes 'creamy' & workable OR
c) ideas on the exact sand & cement (3:1?) I should buy to make my own.
Building with reclaimed brick is challenging enough without having to also contend with questionable mortar.
Many thanks for any experiences or suggestions anyone can share or suggest.
Regards,
Jill-of many trades .. master of none
Rapscallion is offline   Reply With Quote
Old 11-21-2012, 10:33 PM   #2
cheif outhouse engineer
I have probably personally used over 10,000 bags of Quickrete type N and have never had a single problem. You are just gonna have to face the facts and realize that this is not your garden variety DIY skill. If you want to confirm the consistency and creamy feel of real mortar, just buy a bag of Type N masonry cement and mix with mason sand 3 parts sand to 1 part masonry cement and add water to the necessary texture and compare. There is some difference, but not enough to really make any project impossible to complete.
This skill set is something that takes years to hone into productive efficiency. Knowing what portion of the process to adjust for the specifics of the job at hand is something that is counter intuitive and takes years of trial and error or a good mentor to figure out.
Your description sounds to me like your not using enough water. Mix for about five minutes and you should be good to go. Lime can be added and might be needed for reclaimed pavers but you really need lime putty or building lime, not just hydrated lime from a bag.
dakzaag is offline   Reply With Quote
The Following User Says Thank You to dakzaag For This Useful Post:
Old 11-21-2012, 11:39 PM   #3
joed's Avatar
Rewards Points: 11,534
Sounds like you might be adding too much water.
Old 11-22-2012, 01:32 AM   #4
Civil Engineer
Rewards Points: 4,514
If this is old mortar, it can absorb moisture from the air over time, and become useless. I have six bags of Portland cement in the garage that have hardened over the years due to absorption of moisture, of course they are worthless, but they are so heavy I haven't had the desire to take them to the dump.
Old 11-22-2012, 07:23 AM   #5
Try another flavor of "Pre-mix"
Spec mix
Sackrete
Maybe that will help.
Kinda funny that two posts suggesting the opposite approach. Just love the internet...
Old 11-22-2012, 11:35 PM   #6
concretemasonry's Avatar
Rewards Points: 2,566
The brand has little to with mix. Because of the freight costs, the prices will be very similar in your area since local aggregates will be used and all the baggers of cement and preproportioned mixes have the same coice of other materials (cement and lime) to buy for packaging. Some cement companies have cement packed by others because it a low volume. The mixes are designed to meet the ASTM C279 requirements for volume proportioning for the various types of mortar. - In other words, there is a minimal difference in what is in the bag.
Mixing and amount of water and tining can be critical, especially with different local aggregates that are usually rounded, but the gradations can vary from harsh (coarse) to smooth (fine, very round), but all are very similar.
Mixing is very underated, except by very good masonry contractors the will pay a high premium for a good mud mixer (some more than a mason gets) that knows what the masons need for the type of masonry units.
Dick
concretemasonry is offline   Reply With Quote
Old 11-23-2012, 11:47 PM   #7
Thanks to all who have responded, especially those who are mix-masters by trade - sharing your wisdom with newbie DIYers is noble. If I could afford you I would, but I know that you wouldn't even bother to submit a quote on my 15' X 18" small perennial garden retaining wall ... so I have to muster it on my own
Update: I bought a brand new bag of Quikrete Mortar Mix (just add water variety) and mixed a 5-trowel batch in a tub in my kitchen sink with tap water. Hey - Don't laugh too much! Temperatures outside are hovering around 5 deg C. Seemed like the best way to ensure that the mortar was pre-warmed to some extent (P.S. I used cold water though). Haha .. ya, newbie, trying hard.
I made sure not to take less than 5 minutes and not more than 10 minutes to mix it (as recommended on other product websites) and I mixed it quite vigorously using my trowel; flipping, stirring, etc. to get some air-entrainment.
I also didn't attempt to estimate the 'right' amount of water given the 3.7L per 66 lb instructions; I don't have a scale on site. I went by creaminess and vertical hold test.
This batch was fantastic! Spreadable like butter Bricks basically leveled themselves ... it was actually fun!
I think the original problem was due to not adding enough water, as one commentor suggested; most DIYers are fearful of adding too much water given that this may be the only bag they have on-site.
I also believe that, the first time, I spent over 30 minutes mixing a full 66 lbs worth in a wheel barrow. Perhaps over mixing is a problem too?
Hope this helps others in my situation and thanks to all who chimed in encouraging me to try again
Old 11-23-2012, 11:58 PM   #8
Thumbs up
Special thanks to the Chief Outhouse Engineer
Special thanks to the Chief Outhouse Engineer: Should you need some perennials to go with your outhouses, I have an abundance of beautiful multi-petal bright yellow Rudbeckia's (Golden Glow 'Hortensia'), more commonly known as the Outhouse Plant. Link deleted Seriously
Old 11-25-2012, 08:57 PM   #9
Rewards Points: 1,220
Concrete and mortar are not the same product, they just use similar ingredients. There is no such thing as a test for mortar that equates to a slump test for concrete, for example, because the most important characteristic of mortar is workability. This can change the actual mix by each batch, so you have to be able to "faire le mortier aime la truelle".
Normally a bagged type N mortar is going to be much harder to get right than a Type S, so buy Type S if possible.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Rapscallion (11-25-2012)
Old 01-05-2013, 12:04 AM   #10
Guywithskills
the overmixing messes with it trying to set up. Also avoid "shaking up" or remixing when starting to get stiff for same reason.
Guywithskills is offline   Reply With Quote
Tags
"type n" , creamy , mortar , quikrete
"Sandy" mortar on tuck-point repair drm31078 Concrete, Stone & Masonry 7 11-25-2012 09:18 PM
brick mortar issues or foundation? Advice needed. wadegpt General DIY Discussions 4 01-19-2012 02:00 AM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 08:44 AM
Help! Mortar bed problem! sillyboy22 Flooring 8 10-15-2009 03:59 PM
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 10:39 AM
