#1 |
Re-surfacing concrete walls in smokehouse
Hello,
I am working on re-doing an old concrete building and turning it into a smokehouse. I suspect the building could be 75+ years old so the concrete is in pretty rough shape. What I am trying to decide is whether to plaster over the interior walls, or if there is some type of heavy-duty paint/sealant that I could paint over the walls and avoid having to plaster them. I have never plastered anything, but if the process isn't too involved I think it would look nice to have the walls plastered. Is there a good resource to guide me through the process? Also, can someone recommend a good caulk-type sealant that I can shoot into any cracks? Gracias! Travis |
#2 |
i wouldn't do anything w/o 1st press wshing the walls- 4gpm, 3,500psi, & turbo nozzle - we'd use polymer-modified cement but that's our work,,, perhaps a drywall guy can suggest a cheaper short-term solution
1st determine IF cracks're moving/static which will suggest proper repair mtl de nada
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| How to finish concrete walls in cold storage room (basement) | TomU | Concrete, Stone & Masonry | 6 | 11-11-2012 07:40 PM |
| 2" space between poured concrete walls and concrete slab floor | PKEARTH | Concrete, Stone & Masonry | 0 | 09-30-2012 04:50 PM |
| Insulating poured concrete basement walls | Dude | Building & Construction | 0 | 03-03-2010 01:24 PM |
| Wet Concrete Walls: Painting apartments in China | szstevo | Painting | 9 | 01-03-2010 11:04 PM |
| Concrete slab with hot water heat- Moving walls | skizsam | Building & Construction | 16 | 04-06-2009 03:08 PM |
