Raising A Fireplace Hearth - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-11-2013, 06:38 PM   #1
I currently have a hearth that is flush w the floor. We'd like to raise it 6"-12". Can anyone tell me if this is even possible and what material I would need to use to raise the fireplace floor itself? Thanks!
fburdine is offline   Reply With Quote
Old 12-11-2013, 08:08 PM   #2
Rewards Points: 14,014
We have no picture, no mention of what's there now.
Going to need more info.
Old 12-11-2013, 08:22 PM   #3
Sorry, Joe. I'm a newbie.
Old 12-11-2013, 08:27 PM   #4
Why so high?
That's going to make for a tiny opening and look odd.
Old 12-11-2013, 08:43 PM   #5
I guess it doesn't necessarily have to be that high. We simply want to raise the hearth as much as possible to allow for a stone hearth sitting atop that same tile seen in the picture.
Old 12-11-2013, 08:48 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 546
If that is a masonry fireplace IMHO it will have to be torn out and start from scratch, maybe one of the masons can give you some suggestions. I agree with Joe, it sure would look bad just raising the hearth.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-12-2013, 09:37 AM   #7
Concrete & Masonry
Rewards Points: 620
As long as it's a gas or electric log set, I don't see why you can't do it. The opening will be rectangular, but most modern fireplaces are anyways. I don't know that I'd shoot for a whale 12", but 6-8" should still look fine.
You could always run a piece of tape 6-8" above the floor so you can visualize before doing anything.
"If" I were doing it, I'd source a few 6" solid top concrete block, and set them on their side on the sub hearth. You'll need to do a little cutting or chiseling to make them fit, but you can also fill the inside in with rubble/gravel/concrete as well if it's easier. Just make sure you leave the outside face of teh block nice and flush for the tile to lay on.
This should give you an idea of what a 6" solid top looks like. You could use concrete brick as well if they're easier to find, as well as a number of other shapes and sizes:
jomama45 is offline   Reply With Quote
Removing Fireplace Hearth - Questions dschribs Concrete, Stone & Masonry 14 02-25-2013 06:24 PM
Fireplace Hearth is Sinking Jim Ignatowski Building & Construction 9 01-04-2013 11:24 AM
Enlarging an existing fireplace hearth josephmartins Concrete, Stone & Masonry 0 11-09-2012 09:12 AM
Fireplace hearth marriedmanw Concrete, Stone & Masonry 1 10-10-2012 11:38 AM
Fireplace facelife - needing hearth advice louiejr Building & Construction 4 11-25-2009 05:57 AM
