Rainwater In The Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-30-2012, 04:56 PM   #1
rainwater in the fireplace
I have water leaking inside the chimney down into the fireplace area. I can see water running down the brick inside. What is the most likely cause of this? There is no cap on either of the two square concrete pipes exiting the chimney.
tedwin is offline   Reply With Quote
Old 10-30-2012, 05:09 PM   #2
Rewards Points: 1,228
The cause is most likely 1) it's raining or 2) your neighbor is spraying your fireplace chimney with his garden hose.
Old 10-30-2012, 05:31 PM   #3
Rewards Points: 13,694
Really should have a screened cap. It helps the chimmney to draw better, keeps out critters and rain.
If your anywhere near where that hurricane was there not much short of capping the chimmney that would have kept out water.
Old 10-30-2012, 05:33 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
look up your chimney from the fireplace .... if you see blue sky
as Joe said you should have a screen cap to prevent rain/snow but also varmits
of course an event like Sandy can still force water down your screen capped chimney
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-31-2012, 01:21 PM   #5
Rewards Points: 1,232
The cap would allow water into the flue, not the chimney. Most likely the chimney cap (not the lack of a flue cap) is the problem; it is very common.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 06:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
