-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   rainwater in the fireplace (http://www.diychatroom.com/f105/rainwater-fireplace-161653/)
tedwin 10-30-2012 05:56 PM
I have water leaking inside the chimney down into the fireplace area. I can see water running down the brick inside. What is the most likely cause of this? There is no cap on either of the two square concrete pipes exiting the chimney.
SeniorSitizen 10-30-2012 06:09 PM
The cause is most likely 1) it's raining or 2) your neighbor is spraying your fireplace chimney with his garden hose.
joecaption 10-30-2012 06:31 PM
Really should have a screened cap. It helps the chimmney to draw better, keeps out critters and rain.
If your anywhere near where that hurricane was there not much short of capping the chimmney that would have kept out water.
GBrackins 10-30-2012 06:33 PM
look up your chimney from the fireplace .... if you see blue sky
as Joe said you should have a screen cap to prevent rain/snow but also varmits
of course an event like Sandy can still force water down your screen capped chimney
Tscarborough 10-31-2012 02:21 PM
The cap would allow water into the flue, not the chimney. Most likely the chimney cap (not the lack of a flue cap) is the problem; it is very common.
