Rack Attachment Over Faux Stone Above Fireplace Mantle. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-14-2013, 05:53 PM   #1
Rack attachment over faux stone above fireplace mantle.
Faux stone on fireplace. Want to hang flat screen above mantel on wall rack. (previously setting on mantle) Ideas re rack to use on uneven faux stone on fireplace 4-5 inches above mantel. Do not want to damage faux stone. Studs likely accessible behind grout between stone. Don
Don Holben is offline   Reply With Quote
Old 01-14-2013, 08:15 PM   #2
Rewards Points: 1,232
You will have to mount to the studs, not the stone. I am not familiar with flatscreen mounting brackets, but you should be able to use bolts to get you out past the stone.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Reface brick fireplace with faux stone cypherx Concrete, Stone & Masonry 2 06-17-2012 10:43 AM
Are cornerstones needed for faux dry stack stone fireplace? Lisa Highfield Building & Construction 0 06-09-2010 06:36 PM
Arguement over faux stone on a fireplace viper1 Building & Construction 13 01-07-2010 03:52 PM
Question about wood mantle on stone fireplace Daggerhart Remodeling 2 06-15-2008 04:16 PM
