Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-28-2012, 02:11 PM   #1
Quikrete vs. sakrete
It's a stupid thread to get some opinions. Lowes has Sakrete while home depot has quikrete. The Sakrete says its for footings and says it cures in 24 hours while the quikrete just says its for things like fence posts and to allow 5 days to cure completely. What do you guys think? I will be using it as footers for my shed and the shed will be on jacks while it cures. I will also be using rebar.
Opinions?
nikeman is offline   Reply With Quote
Old 03-28-2012, 02:47 PM   #2
bbo
qhikrete has products to match what you are looking to do.
http://www.quikrete.com/PDFs/ConcreteSelectorGuide.pdf
http://www.quikrete.com/PDFs/FastSet...ectorGuide.pdf
sakrete should be much of the same.
you'll need to know the curing times needed and strength needed for your application.
bbo is offline   Reply With Quote
Old 03-28-2012, 03:08 PM   #3
Looks like quikrete 5000 is the way to go. But it's $1 more per bag than the Sakrete so still not sure. I doubt the shed puts 1500 lbs psi on one corner so over night should be fine with rebar I think. I don't like I idea of my shed sitting on jacks for a long period of time with my crazy dog running around back there.
Old 03-28-2012, 04:40 PM   #4
concretemasonry's Avatar
Quikrete and Sakrete are essentially the same products made to minimum mortar or concrete standards and there are not "secrets". They both vary somewhat because they are made from the locally available aggregates that do not have very specific ASTM standards (ASTM C33). Even the preferred proportioning specifications have wide overlapping standards and the concrete strength standards are for lab tests and not actual in-place strengths.
Concrete cures/increases in strength as long as there is moisture available. If a mix says it includes Type III (High Early) cement, it will have higher early early strength, but possibly a lower ultimate strength, but strength is really not important for a fence post foundation.
I had a friend that packaged both Quikrete and Sakrete in the same plant with the same aggregate and cement. He also packaged his own brand plus bagged kitty litter in slower periods.
For a fence post it does not make much difference, but make you feel better.
Dick
concretemasonry is online now   Reply With Quote
Old 03-28-2012, 07:20 PM   #5
I'm using it for footers on my 12x16 shed so strength would be important there
Old 03-28-2012, 09:47 PM   #6
For a 12x16 shed concrete strength is not hat important. You have light loads ans the main problem would be wind for uplift or wind for lateral resistance. For the latter, the above ground structure and the soil properties are most important.
You cannot get an appreciable load on a footing from a 12x16 shed.
Dick
Cracks in Quikrete Resurfacer appleman11 Building & Construction 0 01-23-2011 05:19 PM
Quikrete Question Ruger141 Building & Construction 1 04-23-2010 10:24 AM
quikrete deck forms redroc25 Building & Construction 6 08-14-2009 12:26 PM
Quikrete Shelf Life jrepp Building & Construction 8 01-16-2008 02:40 AM
quikrete cibula11 Building & Construction 1 06-11-2007 12:33 PM
