Question About Staining Concrete In My Den - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-27-2012, 10:13 PM   #1
Question about staining concrete in my den
I recently purchased a home with a sunken den that I removed carpet from. After removing tack strips, the nails pulled up some of the concrete and I know that must be patched prior to staining. There are also a few minor glue marks that I can clean, hopefully.
For the most part the floors are fairly smooth but there is a section or two thats kind of rough, textured like a sidewalk would be but nothing too horrible. Should this be sanded/grinded smooth prior to staining or is a little texture ok for interior floors?
Any recommendations on good cleaning and patching products to fill the tack strip chips?
not4sakn is offline   Reply With Quote
Old 03-27-2012, 10:43 PM   #2
Rewards Points: 13,450
Every flaw, stain, patch will show up when staining the concrete.
It would also have to be etched with acid.
Concider having a pro concrete finisher take a look at it or go to plan B on a differnt type of flooring.
Old 03-27-2012, 10:50 PM   #3
I dont mind thoroughly cleaning, etching, or buffing the floor if necessary. I'm just wondering if all minor imperfections must be fixed first or if you can simply stain over them. I understand they'll show through, but does it really matter? Some people choose to leave minor cracks because it adds character and gives it a worn look.
Old 03-28-2012, 07:19 AM   #4
Concrete & Masonry
Rewards Points: 548
If it's being stained with an acid stain, that's the last thing he'd want to do.............
jomama45 is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Roof Cap / Staining - Lichen Question butchbs1985 Roofing/Siding 1 09-06-2011 09:58 AM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 06:16 AM
Staining concrete flooring - questions on cleanup and relief cuts vseven Flooring 3 12-15-2009 08:07 AM
Concrete question Daniel O'Connor General DIY Discussions 1 11-22-2004 02:54 PM
