Question About Slope Of Garage Slab Foundation - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-18-2012, 10:51 PM   #16
Concrete & Masonry
Rewards Points: 470
Originally Posted by ddawg16 View Post
Recheck your math....his spec was 1" per 10'....on a 24' garage, that would be about 2.5"....which is a lot. My garge is 25" and it slopes about 1"....and I don't have an issue getting water out.
pttc.....I would 'highly' suggest stem walls. Without them, your going to be cutting every single 2x4 stud a different length if you want you roof to be flat.
Click on the link in my signature for the Garage build....I went through it about 2 years ago.
Mike was referring to the minimum I suggested, not the min. mentioned by the OP, at least from what I can tell.
After looking at your garage build picture, it appears you could have really benifitted from a little additional pitch on the garage floor. The ramp to the garage must drop 5" in 3'................
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
pttcc (01-18-2012)
Old 01-18-2012, 10:59 PM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 802
I think the pitch is fine....any more and I would find it uncomfortable to walk on....I do a lot of woodworking and I like a flat floor....but if water does get on it...it flows out fine.
As for the ramp into the garage....sore point....I was pissed at the contractor for making it so steep.....
Once I'm done with my 2-story addition...I'm going to replace the existing driveway with one without 'cracks'....and I'll saw cut the ramp and make it more gradual....
The Following User Says Thank You to ddawg16 For This Useful Post:
pttcc (01-18-2012)
Old 01-18-2012, 11:02 PM   #18
Old School
Willie T's Avatar
We usually run 2 to 2.5 minimum on 20' slabs here.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
pttcc (01-18-2012)
Old 01-18-2012, 11:18 PM   #19
firehawkmph's Avatar
Rewards Points: 1,798
Interesting thread guys. I guess everybody does it a little different depending on where you are. Most of the attached garages around here get a drain in the middle that is tied into the sanitary in the basement. With the drain in the middle of a 24' x 24' garage, the guys usually pitch everything towards the drain in the middle with 1 1/2" being the fall. In my shop I have two areas. One is 28' x 56', the new addition onto that is 28' x 36' to make the building an ell shape. The original floor is poured flat with no drains. I didn't want any pitch in my shop area. When I do park in there, the snow melting off my van will leave a slight puddle around the wheels, most of the water hits the cut joints and finds its way out. The new addition we poured the floor flat except for the first 9' coming in from the doors. That area has a 3/4" pitch. I am planning on putting a twin post auto lift in there on one side and it calls for a flat floor.
I definitely agree with the stem wall. Around here the bottom plate has to be at least 8" higher than grade.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
pttcc (01-18-2012)
Old 01-18-2012, 11:23 PM   #20
Concrete & Masonry
Rewards Points: 470
You "Think" it would be uncomfortable, but the reality is you wouldn't ever know the difference unless you could eyeball it next to the level curb. ANd, there's no correlation between a flat floor & a pitched floor. You can have both in conjunction, and they have no bearing on each other.
Other than replacing alot more of your driveway or putting more pitch on the slab, what other option did he really have?
I think you're missing my main point here. You paid a professional to install the floor, with minimal pitch, and it still shed water to your satisfaction. For someone to attempt this with little to no experience, they're likely to have puddles or "duck ponds"......
pttcc (01-18-2012)
Old 01-18-2012, 11:30 PM   #21
Concrete & Masonry
Rewards Points: 470
Mike Hawkins
Mike, if you consider that you're dropping that 1.5" in only half the distance (12' at most), you'll see that it's the equivalent to 3" in 24'. 3" really isn't that much different than the 3.5" I mentioned earlier...........
I certainly agree though that different regions have different requirements. Parts of the South that don't get freezing precip. dropping off of parked vehicles, or much rain, likely don't need the same amount of pitch. Also, dry concrete will absorb fairly large amounts of water more rapidly if the pitch isn't sufficient.
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
firehawkmph (01-19-2012), pttcc (01-18-2012)
Old 01-18-2012, 11:39 PM   #22
If I'm just trying to run water I use an 1/8 per foot as a min. slope. We do monolithic garages all the time here as long as they meet requirements for frost protection. I don't usually slope detached garages. I just slope the approach pad and drive way.
Ninjaframer is offline   Reply With Quote
The Following User Says Thank You to Ninjaframer For This Useful Post:
pttcc (01-18-2012)
Old 01-18-2012, 11:48 PM   #23
Could you explain a little bit why you don't usually slope detached garages? Thanks!
pttcc is offline   Reply With Quote
Old 01-18-2012, 11:57 PM   #24
It's not required. At least not in Utah. And it totally depends on intended use, if your not going to be hosing the floor down how is water going to get inside? Your door will have a weather seal that will prevent rain fall from getting in. Now if you need to be able to spray down the floor you should slope it but then you don't want a mono slab, you want stem walls with the floor set below there grade.
pttcc (01-19-2012)
Old 08-04-2013, 04:24 PM   #25
Originally Posted by AndyGump View Post
HI Pete, (I'll just call you Pete if you don't mind) a monolithic slab is fine yes.
But usually you will have a detail something like this to show the garage wall attachment to the foundation showing a stem wall.
Your plans do not have this?
This is just something I threw together to illustrate, your plans would be much more detailed than this.
Andy.
I hope this reaches Andy???
I saw your sketch in a post from 1/2012. It's exactly what I want for my garage.I haven't been able to find instructions, diagrams, pictures of the framing to construct to create the monolithic footer/slab/stemwall you described. Is there a web site, how to book, or whatever that I can obtain to see how this would be formed?
cmctyankee is offline   Reply With Quote
Old 08-05-2013, 09:31 PM   #26
Concrete & Masonry
Rewards Points: 470
Pretty sure Andy draws for a living, I'm sure he could hook you up with whatever you need for a small fee..............
AndyGump (08-08-2013)
Old 08-08-2013, 04:51 PM   #27
Rewards Points: 3,342
Don't know if this will help,but i like the wall to be 6/8 inches higher than the slab.
http://www.google.com/imgres?imgurl=...9QEwDA&dur=232
Canarywood1 is offline   Reply With Quote
Old 08-08-2013, 05:40 PM   #28
JOATMON
ddawg16's Avatar
Rewards Points: 802
Look at the pics in my Garage build link (in my signature).
Depending on where you are, you might need drawings from an architect.
Any decent concrete guy will know what to do.
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage insulation question silverfox103 Insulation 0 10-05-2011 10:10 AM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 09:31 PM
Garage Foundation cibula11 Building & Construction 5 08-08-2009 02:36 PM
