Putting Ledgestone Around A Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-14-2012, 04:33 PM   #1
Putting ledgestone around a fireplace
We have just picked out ledgestone to go around our existing fireplace. The gas fireplace is flush with the drywall. So, when the ledgestone is installed, the edge of the ledgestone (which is white) will show all around the fireplace. We are in a real quandary what to do about this? The fireplace can do be pulled out-it is hooked to the chimney.
Ideas?
Thanks,
Sharon
friscosharon is offline   Reply With Quote
Old 04-14-2012, 09:36 PM   #2
Rewards Points: 13,300
Post a picture
Old 04-14-2012, 09:45 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You can look into tile edging trim/transitions and border edging.
Gaps can be filled with a color matched (To the stone's surface face color) - sanded caulk, grout, or standard caulking.
Picture examples: http://www.bing.com/images/search?q=tile+edging+trim&qpvt=tile+edging+trim&FO RM=IGR
- Build Well -
Can I mount my flatscreen inside the fireplace opening? minpin Home Theater 15 03-04-2013 02:03 AM
[Pics Inside] Unsure what this part does (electrical fireplace switch) rdiggidy Electrical 4 09-07-2009 07:14 PM
Fireplace remodel -- need advise & suggestions mwehnes Building & Construction 12 06-28-2009 10:36 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
Adding a gas fireplace BionicWoman Remodeling 7 11-08-2007 01:53 PM
