Putting Footings Under Existing Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-05-2014, 09:34 PM   #1
We have a cement slab on the side of our house where we park our 36 ft motor home. We recently installed a 17'x40' metal cover for the motor home. (looks like a carport but bigger) We've been told that we need footings in order to get a permit to keep it otherwise we have to have it dismantled (its a long story why we didn't get a permit first). My question is: Is there a way to put the footings in at this stage and how much does something like this cost?
Thank you
shirken3 is offline   Reply With Quote
Old 08-05-2014, 10:41 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
Since you did not give your location or much else, you will only get guesses about and approximate cost.
In general, you must provide footings at each of the vertical posts (however many you have). If it is supported by you home, you will additional problems.
For a lightweight cover, you just to to edge it up a bit to remove the supports and build some acceptable foundation, replace the posts and lower the cover as you removed the temporary support. You might get lucky and be able to do it one post at a time.
Since you tried to avoid a permit or inspection, you can be expected to be watched closely. I would imagine you may need some kind of soil report to verify the design and ability to provide sufficient vertical capacity and lateral strength/stability. You might even have to provide a way to provide anchorage methods to prevent owning a 17'x40' "wing" flying around the area.
edit - To put footings under the slab, you can cut holes wherever needed, excavate for footings (Sonotubes or concrete piers or similar) and then patch the concrete slab.
Dick
concretemasonry is online now   Reply With Quote
Old 08-06-2014, 01:14 AM   #3
Footings Under existing slab
Thank you for the information. I am in San Bernardino county in Southern California. Any idea of cost? I know you cant be exact but are we talking hundreds or thousands to have something like this done? The RV cover cost $5000 to have installed so obviously I don't want to pay more than it cost me to have footings put in. It would be cheaper to just let it go.
Old 08-06-2014, 07:27 AM   #4
joed's Avatar
Rewards Points: 11,576
Costs vary too much by location. Call several contractors for estimates.
Old 08-06-2014, 09:34 AM   #5
Rewards Points: 626
well how thick is the slab?and what type of footings are they requiring? pier type? a full length perimeter footing? how thick do they want the footing 6", 8" or 10"
These are all the questions we need the answers to. In order to provide more suitable replies. I will say this to all who read this post. Get a permit when it is required! it is cheaper in the long run and they will work with you.
Nailbags is offline   Reply With Quote
Old 08-06-2014, 09:39 AM   #6
Rewards Points: 626
Why not use something like this?
http://www.sheltersofamerica.com/pro...uctid=655&id=3
It is not a permeant structure and hence you might not need footings.
Old 08-06-2014, 01:58 PM   #7
Definitely not a permanent solution with two problems.
1. It will last until the first good storm and has no real guarantee in the end.
2. If the home is put on the market, a quick look would be to devalue the actual home (it is bad sign of things to come). Even when sold, it will be reasonably easy to dispose of (some labor and a couple of loads).
Dick
Old 08-06-2014, 03:28 PM   #8
Rewards Points: 4,454
dick, looks like the beverly hillbillies've moved in but, at least, you wouldn't need a bldg permit,,,,, OOOPS wait a minute - this is in KALLEFORNIA ? ? ? you might
irc
Old 08-06-2014, 05:19 PM   #9
Concrete masonry is right. My guess would be pier footings at all the point loads. You can build temp supports are puns each vertical point load. Then cut the concrete and dig and dig and dig. Inspector will then come out to check the depth. Then get some sonotubes and pour the footers. Ask the inspector what he would like to see for your attachment method to the footers. I would flare the bottoms of the holes and throw a few inches of gravel. This will help if that wind kicks up and that"wing" goes up and takes the footers with it.
I would also pour concrete higher than the existing deck in order for you to slope the top of the pour I'm order to shed water. This may require jacking up the car port to accommodate.
By the way you described it, it doesn't seem like this is a job you would tackle yourself. Start getting estimates.
ChrisMDL is offline   Reply With Quote
Old 08-06-2014, 05:21 PM   #10
Edit: "build temp supports at each vertical location/ point load"
sunken sidewalk to raise D270 Concrete, Stone & Masonry 6 11-02-2013 12:52 PM
Building on existing 4" slab workdog Building & Construction 3 09-14-2013 08:59 PM
pouring slab for existing foundation? panteramatt Concrete, Stone & Masonry 4 03-23-2013 04:41 PM
Deck footings closer than 5' to an existing exterior house wall oatlord Building & Construction 9 09-05-2011 11:12 PM
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
