Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-26-2013, 04:40 PM   #1
Proper way to install decorative concrete trim
People,
Having a stucco guy do stucco on garage face (2 garage doors facing road). He is gonna install (glue on/cement on) decorative lightweight trim around both door openings.
Thing is- he placed the trim where the inside edge of the trim is FLUSH with the inside door opening. Thereby, no "reveal" edge which, to me, enhances the trim look, like a carpenter would do on an inside doorway with casing trim- theres ALWAYS a reveal edge, about 1/8' to 2/8" or so (varies).
What do you think? Can /should exterior concrete trim have a "reveal"?
Thaks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-26-2013, 05:39 PM   #2
heres an example of the trim
http://www.foamdesigncenter.com/outd...itfdctk02.aspx
Old 01-26-2013, 06:50 PM   #3
"Thereby, no "reveal" edge which, to me, enhances the trim look, like a carpenter would do on an inside doorway with casing trim- theres ALWAYS a reveal edge, about 1/8' to 2/8" or so (varies)."
Problem is he's not a carpenter, he's a stucco guy as you said,and they do things a little different, when you contract with someone to do a job for you, do it in writing so all parties understand each other, and NEVER ASSUME ANYTHING.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
bricklayermason (01-26-2013)
Old 01-26-2013, 08:59 PM   #4
2/8's? Hmm is that close to 1/4"?
Old 01-27-2013, 08:52 AM   #5
One can not encompass all unforseens in a contract, which in fact, I do have. The reason for my thread is to get opinions on what is customary on concrete trimming, not if I should have had a written contract. Maybe a reveal does not normally apply to stucco work (?)
I should have added- he already put the trim onto the 1st coat. Is that normal? Guess hes gonna put finish coat and feather it onto the trim(?) Is that normal? Thats what Im after. I cant dictate to him what to do as orthodox stucco practices........
Old 01-27-2013, 09:33 AM   #6
Not so new
12penny's Avatar
If the trim is on top of the first coat, then I would think you would have a reveal. Color coat is only 1/8" or so.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
noquacks (01-27-2013)
Old 01-27-2013, 11:30 AM   #7
Normally foam popouts get a coat of base/coat adhesive. Are you using a synthetic finish coat?
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 01-27-2013, 01:44 PM   #8
Thanks, T, but not sure what youre asking. If youre asking about how he glued the trim on, I think with concrete. Dont know what finish coat he will use. I did have 3 bags of quick dry stuff from HD hes using- not sure though, it it will be enough for the finish, although, if it will be enough, I understand it also can be used for finish.
Old 01-27-2013, 02:15 PM   #9
Foam shapes are normally used on EIFS systems, not 3 layer cementious stucco systems. It is possible to use a synthetic finish over cementious stucco, but the foam has to be coated with a thin, high strength coat before the finish coat, otherwise every time you bump in to it, it will dent and crack.
Old 01-27-2013, 06:37 PM   #10
I think I get it now. Thanks, T, and other members.
Decorative Concrete Flooring: Creating Molds Brainstorming Needed soapage Flooring 2 11-28-2012 04:47 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Install hooks in a concrete ceiling? adamsanderson Carpentry 12 07-29-2011 10:53 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
