-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Proper way to install decorative concrete trim (http://www.diychatroom.com/f105/proper-way-install-decorative-concrete-trim-170185/)
noquacks 01-26-2013 04:40 PM
People,
Having a stucco guy do stucco on garage face (2 garage doors facing road). He is gonna install (glue on/cement on) decorative lightweight trim around both door openings.
Thing is- he placed the trim where the inside edge of the trim is FLUSH with the inside door opening. Thereby, no "reveal" edge which, to me, enhances the trim look, like a carpenter would do on an inside doorway with casing trim- theres ALWAYS a reveal edge, about 1/8' to 2/8" or so (varies).
What do you think? Can /should exterior concrete trim have a "reveal"?
Thaks!
noquacks 01-26-2013 05:39 PM
heres an example of the trim
http://www.foamdesigncenter.com/outd...itfdctk02.aspx
Canarywood1 01-26-2013 06:50 PM
"Thereby, no "reveal" edge which, to me, enhances the trim look, like a carpenter would do on an inside doorway with casing trim- theres ALWAYS a reveal edge, about 1/8' to 2/8" or so (varies)."
Problem is he's not a carpenter, he's a stucco guy as you said,and they do things a little different, when you contract with someone to do a job for you, do it in writing so all parties understand each other, and NEVER ASSUME ANYTHING.
joecaption 01-26-2013 08:59 PM
2/8's? Hmm is that close to 1/4"?
noquacks 01-27-2013 08:52 AM
One can not encompass all unforseens in a contract, which in fact, I do have. The reason for my thread is to get opinions on what is customary on concrete trimming, not if I should have had a written contract. Maybe a reveal does not normally apply to stucco work (?)
I should have added- he already put the trim onto the 1st coat. Is that normal? Guess hes gonna put finish coat and feather it onto the trim(?) Is that normal? Thats what Im after. I cant dictate to him what to do as orthodox stucco practices........
12penny 01-27-2013 09:33 AM
If the trim is on top of the first coat, then I would think you would have a reveal. Color coat is only 1/8" or so.
Tscarborough 01-27-2013 11:30 AM
Normally foam popouts get a coat of base/coat adhesive. Are you using a synthetic finish coat?
noquacks 01-27-2013 01:44 PM
Thanks, T, but not sure what youre asking. If youre asking about how he glued the trim on, I think with concrete. Dont know what finish coat he will use. I did have 3 bags of quick dry stuff from HD hes using- not sure though, it it will be enough for the finish, although, if it will be enough, I understand it also can be used for finish.
Tscarborough 01-27-2013 02:15 PM
Foam shapes are normally used on EIFS systems, not 3 layer cementious stucco systems. It is possible to use a synthetic finish over cementious stucco, but the foam has to be coated with a thin, high strength coat before the finish coat, otherwise every time you bump in to it, it will dent and crack.
noquacks 01-27-2013 06:37 PM
I think I get it now. Thanks, T, and other members.
