Problem In The Water Heater Closet - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-27-2014, 05:38 PM   #1
Rewards Points: 89
Problem in the water heater closet
I have my water heater in a closet that has a concrete floor. Well, there's a problem with that concrete floor. See attached. How do I fix this?
Fly_on_the_wall is offline   Reply With Quote
Old 01-27-2014, 05:55 PM   #2
DIY staff
Rewards Points: 7,174
How big is that gap? Why is it there?
Old 01-27-2014, 06:23 PM   #3
Rewards Points: 13,712
Unpressure treated wood in direct contact with concrete? Why is there wood there?
Old 01-27-2014, 06:32 PM   #4
Rewards Points: 89
This is how big the gap is (see attached). As to why it's there, I don't know. The home was a fixer-upper with many problems and this is one of them. I'm still in the process of fixing up this place, but the finish line is almost there.
The wood is the baseboards (only for that closet) that the previous owners put there.
Problem in the water heater closet-cam00061.jpg   Problem in the water heater closet-cam00065.jpg
Old 01-27-2014, 06:43 PM   #5
? Baseboard would be on top of a finished floor, and not recessed into what every that is on the wall.
Notice all the water stains on the wood?
Old 01-27-2014, 06:48 PM   #6
DIY staff
That is a chase way for pipes---to neaten that up---pack with insulation and then put a thin layer of patching cement over the insulation---if those pipes ever need service--the thin cement patch could be popped out---
Old 01-27-2014, 06:56 PM   #7
Rewards Points: 89
For some reason, the previous owners didn't finish putting the tile in that closet.
The water damage is probably from the water heater.
What kind of insulation? I'm familiar with the kind of insulation that goes in the attic, but not this kind of insulation.
Old 01-28-2014, 04:54 AM   #8
DIY staff
Anything that will hold up the cement---fiberglass---
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 01:53 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Problem with pressure release valve in hot water heater? da_man Plumbing 3 08-16-2011 08:14 AM
