Power Tool To Remove Caulk From Brick - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-13-2013, 04:57 PM   #1
Rewards Points: 194
Power Tool to remove caulk from brick
Two layers of silicone caulk seals the garage frame sides to the house brick. I used 3M Caulk Remover but left it on too long so the hot sun baked it dry. Working in 100 degree temps so something other than a hand scraper is perferred.
Would a wire brush wheel powered by my drill help me quickly take the caulk off the brick?
Other suggestions please. Thanks!
sore thumb is offline   Reply With Quote
Old 09-13-2013, 06:03 PM   #2
Rewards Points: 2,516
I tried that and it didnt work too good. The wire brush got all gummed up.
I ended up using a heat gun moderately and several scrapers and pointed toolls.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
sore thumb (09-13-2013)
Old 09-13-2013, 06:23 PM   #3
Rewards Points: 13,960
Oscillating tool with the blade with no teeth on it..
Old 09-13-2013, 06:26 PM   #4
DIY staff
Rewards Points: 7,174
I use a multi tool--Oscillating Tools - Oscillating Multifunction Power Tools
I use a worn out wood blade---this removers the ugliest caulk quickly ---Mike----
Old 09-13-2013, 07:53 PM   #5
Rewards Points: 194
Could you please provide a link to such a blade (@home depot if possible). I have no clue about such a blade.
Thanks,
Old 09-13-2013, 08:21 PM   #6
DIY staff
I think he might be talking about a worn out one----however, all the machines come with a smooth scraper blade----but I would just use the wood blade---
See if you have a harbor freight store near by---the machine they sell is dirt cheap and well built---and replacement blades cost much less the all of the other brands--
A simple inexpensive tool will serve you well for your needs.
sore thumb (09-14-2013)
Old 09-14-2013, 07:16 AM   #7
Rewards Points: 194
I now know which blade jocaption was referencing. Thanks.
Old 09-14-2013, 07:22 AM   #8
DIY staff
Those are easy tools to use--and handy for a lot of things----look for a cheap one----
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
Remove silicon caulk acerunner Remodeling 6 11-16-2011 02:55 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
what tool to rent to remove cultured stone tgseaver Tools 4 09-07-2009 08:09 PM
DIY for home improvememt with power tool kakakawai General DIY Discussions 3 11-12-2005 08:47 AM
